Need help in BoxPlot
vivek
Post by vivek » Thu Aug 13, 2009 9:17 am
I want to select multiple box plot points and then exclude and include according to the selection.
How to acheive this.
Re: Need help in BoxPlot
Post by Sandra » Fri Aug 14, 2009 11:01 am
Hello vivek,
I found a solution for you and you can use a similar code for this in your application. Please see next code and check works as you want:
InitializeChart:
            InitializeChart();
        bool[] Selected1;
        bool[] Selected2;
        bool[] Selected3;
        bool drawrectangle;
        Steema.TeeChart.Styles.Box box1, box2, box3;
        Rectangle rect;
            //-----------------INITIALIZE CHART WITH BOXPLOT-----------------------//
            box1 = new Steema.TeeChart.Styles.Box(tChart1.Chart);
            box2 = new Steema.TeeChart.Styles.Box(tChart1.Chart);
            box3 = new Steema.TeeChart.Styles.Box(tChart1.Chart);
            tChart1.Aspect.ClipPoints = true;
            drawrectangle = false;
            box1.FillSampleValues();
            box2.FillSampleValues();
            box3.FillSampleValues();
            box1.Position = 1;
            box2.Position = 2;
            box3.Position = 3;
            box1.Color = Color.Red;
            box2.Color = Color.Yellow;
            box3.Color = Color.Green;
            box1.Title = "Box1";
            box2.Title = "Box2";
            box3.Title = "Box3";
            box1.Pointer.Visible = true;
            box2.Pointer.Visible = true;
            box3.Pointer.Visible = true;
            Selected1 = new bool[box1.Count];
            Selected2 = new bool[box2.Count];
            Selected3 = new bool[box3.Count];
            tChart1.Panning.MouseButton = MouseButtons.Middle;
            tChart1.MouseMove += new MouseEventHandler(tChart1_MouseMove);
            tChart1.MouseUp += new MouseEventHandler(tChart1_MouseUp);
            tChart1.MouseDown += new MouseEventHandler(tChart1_MouseDown);
            box1.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(box1_GetPointerStyle);
            box2.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(box1_GetPointerStyle);
            box3.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(box1_GetPointerStyle);
            tChart1.Draw();
            ResetCoords();
Event of the project:
            if ((X0 != -1) && (Y0 != -1))
                if (drawrectangle)
                    g.Brush.Visible = false;
                    g.Pen.Color = Color.Black;
                    g.Rectangle(X0, Y0, X1, Y1);
            for (int i = 0; i < Selected1.Length; i++)
                for (int j = 0; j < tChart1.Series.Count; j++)
                    Point p = new Point(tChart1[j].CalcXPos(i), tChart1[j].CalcYPos(i));
                    Rectangle rect1 = new Rectangle(p.X - box1.Pointer.HorizSize - 5, p.Y - box1.Pointer.VertSize - 5, (box1.Pointer.HorizSize + 5) * 2, (box1.Pointer.VertSize + 5) * 2);
                    switch (j)
                        case 0:
                            if (Selected1[i])
                                g.Pen.Color = Color.Blue;
                                g.Ellipse(rect1);
                            break;
                        case 1:
                            if (Selected2[i])
                                g.Ellipse(rect1);
                            break;
                        case 2:
                            if (Selected3[i])
                                g.Ellipse(rect1);
                            break;
                    if (Selected1[i] && Selected2[i] && Selected3[i])
                        g.Ellipse(rect1);
        void tChart1_MouseDown(object sender, MouseEventArgs e)
            if (e.Button == MouseButtons.Right)
                drawrectangle = true;
                X0 = e.X;
                Y0 = e.Y;
        void tChart1_MouseUp(object sender, MouseEventArgs e)
                rect = new Rectangle(X0, Y0, e.X - X0, e.Y - Y0);
                        if (j == 0)
                            if (rect.Contains(p))
                                Selected1[i] = true;
                                Selected1[i] = false;
                        else if (j == 1)
                                Selected2[i] = true;
                                Selected2[i] = false;
                        else if (j == 2)
                                Selected3[i] = true;
                                Selected3[i] = false;
                ResetCoords();
            tChart1.Draw();
        private int X0, Y0, X1, Y1;
        void tChart1_MouseMove(object sender, MouseEventArgs e)
                X1 = e.X;
                Y1 = e.Y;
            tChart1.Invalidate();
        void box1_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
            e.Style = Steema.TeeChart.Styles.PointerStyles.Circle;
            if (e.ValueIndex != -1)
                if (Selected1[e.ValueIndex])
                    e.Color = Color.Red;
                else if (Selected2[e.ValueIndex])
        private void ResetCoords()
            X0 = -1;
            Y0 = -1;
I hope will helps.
vivek
Post by vivek » Wed Aug 19, 2009 2:54 pm
Hello Sandra,
I am facing problem with this code.
1. I am unable to select the 1st box
2. Unable to select the outlier points of each box.
3. When I select a box plot series , Its drawing only circle instead of highlighting the selected points.(The color of the points should be changed.)
How to exclude and include selected points and redraw the particular box from box series?
with regards,
Vivek J
Post by Sandra » Thu Aug 20, 2009 10:48 am
Hello vivek,
I have made changes in last code I send you, and I think works correctly and you could use a similar code as next:
            InitializeChart();
        bool[] Selected1;
        bool[] Selected2;
        bool[] Selected3;
      //  Steema.TeeChart.Styles.Line line;
        bool drawrectangle;
        Steema.TeeChart.Styles.Box box1,box2,box3;
        Rectangle rect;
            //------------------INITIALIZE CHART WITH LINE--------------------------//
            //line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
            //line.FillSampleValues();
            //line.Pointer.Visible = true;
            box1.Position = 1;
            box2.Position = 2;
            box3.Position = 3;
            box2.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(box2_GetPointerStyle);
            box3.GetPointerStyle += new Steema.TeeChart.Styles.CustomPoint.GetPointerStyleEventHandler(box3_GetPointerStyle);
            tChart1.Draw();
            ResetCoords();
                if (drawrectangle)
                    switch(j)
                        case 0 :
                            if (Selected1[i])
                                g.Ellipse(rect1);
                                box1.Pointer.Brush.Color = Color.Red;
                            break;
                        case 1 :
                            if (Selected2[i])
                                g.Ellipse(rect1);
                                box2.Pointer.Brush.Color = Color.Yellow;
                            break;
                      case 2 :
                          if (Selected3[i])
                              g.Ellipse(rect1);
                            box3.Pointer.Brush.Color = Color.Green;
                        break;
                        g.Ellipse(rect1);
                X0 = e.X;
                Y0 = e.Y;
                        if (j == 0)
                       // Point p1 = new Point((tChart1[j] as Steema.TeeChart.Styles.Box).CalcXPos((int)(tChart1[j] as Steema.TeeChart.Styles.Box).MildOut.Series[i].X), (tChart1[j] as Steema.TeeChart.Styles.Box).CalcYPos((int)(tChart1[j] as Steema.TeeChart.Styles.Box).MildOut.Series[i].Y));
                                Selected1[i]=true;
                                Selected1[i]=false;
                        else if (j == 1)
                                Selected2[i] =false;
                        else if (j == 2)
                ResetCoords();
            tChart1.Draw();
                X1 = e.X;
                Y1 = e.Y;
        // Add GetPointerStyle for 3 box plots.
                if (Selected1[i])
                    series.Pointer.Brush.Color = Color.GreenYellow;
        void box3_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
            for (int i = 0; i < Selected3.Length; i++)
                if (Selected3[i])
    // Add Get PointerStyle for 3 box plots.
        void box2_GetPointerStyle(Steema.TeeChart.Styles.CustomPoint series, Steema.TeeChart.Styles.GetPointerStyleEventArgs e)
            for (int i = 0; i < Selected2.Length; i++)
                if (Selected2[i])
            X0 = -1;
            Y0 = -1;
Please check previously code works fine. For check that works you have do next:
For select points:
Click with button Right and draw rectangle of size that you want and containing points.
For unselect:
Click with button Right in the canvas of your Chart.
I hope will helps.
vivek
Post by vivek » Thu Aug 20, 2009 12:25 pm
Hi Sandra,
Thanks, for the new code. It works fine but it's not fulfilling my requirements. I have attached a .zip file which contains a document for the requirements of box plot.
Also I need to know how to exclude and include points ( which may be in box or may be as an outlier ) from that particular series and redraw the graph accordingly.
Thanks for your co-ordination,
with regards,
Vivek J.
Box Plot Requirement.zip
(55.28 KiB) Downloaded 1199 times
Post by Sandra » Mon Aug 24, 2009 12:04 pm
Hello vivek,
1) Only the points at the Q1 of each box is getting selected and not all the points of the box.
I couldn't reproduce your issue, please see next image:
Unable to select the circular point of 1st box (which is in the rectangular box ) and change its color .
I couldn't reproduce your this problem:
If you want reproduce same with image, you could say what is your version of TeeChartFor.Net?
For select points:
For unselect:
Click with button Right in the canvas of your Chart and drop the mouse.
Here the Color of the box is getting changing when selected instead of changing the color of the point using which box plot is plotted.
I could reproduce your problem, and now, isn't possible paint only MidleOut of BoxPlot series, I have added your suggestion in Feauter Request with number[TF02014359] to regards in features versions of TeeChartFor .Net.
vivek
Post by vivek » Mon Aug 24, 2009 2:54 pm
Hello Sandra,
We are using "Steema TeeChart for .NET v3"
The TChart dll version is "3.5.3425.20244".
We have installed TeeChartNET3VSNET2005.
With regards,
Vivek.J
vivek
Post by vivek » Mon Aug 24, 2009 3:12 pm
Hello Sandra,
Instead of marking with circle, Is it possible to change the color of those points which is represent outside of the boxplot.
With regards,
Vivek.J
Post by Sandra » Tue Aug 25, 2009 9:35 am
Hello vivek,
I have to communicate that I check the project using version 3 and I could reproduce your problems. I think the problem is when calculate the X position. I have added this in the list of Bug Report with number [TF02014361]. We will try to fix it for next versions of TeeChart .NET.
You, could change the color of outside points of BoxPlot(MiddleOut or ExtrOut), but as I said in last post, There is a Feauter Request with number[TF02014359] that explain that when selected the point outside plot is not possible change the color only this when is selected. But If you want change the color for Outside boxplot, because there aren't transparents please see next lines of code:
            box1.MildOut.Transparency = 0;
            box2.MildOut.Transparency = 0;
            box3.MildOut.Transparency = 0;
            box1.MildOut.Brush.Color = Color.GreenYellow;
            box2.MildOut.Brush.Color = Color.GreenYellow;
            box3.MildOut.Brush.Color = Color.GreenYellow;
vivek
Post by vivek » Tue Aug 25, 2009 10:35 am
Hello Sandra,
As we have to include these features(Exclude/Include option in Boxplot) in our client application, we need the fixed version as soon as posible. Could you please give me the aproximate date, when can we get the fixed version.
With regards,
Vivek.J
vivek
Post by vivek » Tue Aug 25, 2009 2:40 pm
Hello Sandra,
What is the latest version of Tchart-for-.Net 2005 available in market?
Will it supporting the Boxplot selection features?
With Regards,
Vivek.J
Post by Narcís » Tue Aug 25, 2009 3:01 pm
Hi Vivek,
It's TeeChart for .NET 2009 (v4). Yes, it works as Sandra posted here. You may download the fully functional evaluation version here and update your v3 license here.
vivek
Post by vivek » Wed Aug 26, 2009 4:22 am
Hi Narcis,
Will it support for Visual studio 2005.
With Regards,
Vivek.J
Post by Narcís » Wed Aug 26, 2009 7:18 am
Hi Vivek,
Yes, it includes installers for VS2003, VS2005 and VS2008.
vivek
Post by vivek » Sat Sep 05, 2009 11:41 am
Hello Sandra,
We puchased TeeChart for .NET 2009 (v4).
Now the sample code is working fine.
How to change the selected ExtrOut/MildOut point color?
When we use the following code to change the ExtrOut color, its changing all ExtrOut points
box1.ExtrOut.Transparency = 0;
box1.ExtrOut.Brush.Color = Color.DarkBlue;
How to change the Individual points?
I have used the following code to change the ExtrOut point color. Its not working.
box2.ExtrOut.Transparency = 0;
box2.ExtrOut.Series[0].Color = Color.DarkBlue;
box2.ExtrOut.Series[valueIndex].Color = Color.DarkBlue;
With regards,
Vivek.J
