The horizontal grid lines are overlapped on right axes
Pradip
Post by Pradip » Fri Jul 10, 2009 5:51 pm
hi
please see below image
for more clear picture please see this images
the horizontal grid lines (which are gray in color) are overlapping on the axes on the right side(black in color).
in 400% zoom the lines are more cleares and it looks like the right side axis is cutting.
please give us any solution so that we can resolve this defect.
thank in advance.
Re: The horizontal grid lines are overlapped on right axes
Post by Sandra » Mon Jul 13, 2009 10:16 am
Hello Pradip,
I could reproduce your problem with last versions of TeeChartFor .Net, and I have conciderated add to list bug reports with number [TF02014289], we will try to fix it for next versions of TeeChart .NET.
On the other hand, I make a simple code that solve your problem,drawing directly in the canvas a line.Please check that next code works fine in your application.
          Steema.TeeChart.Styles.Line line = new Steema.TeeChart.Styles.Line(tChart1.Chart);
          line.FillSampleValues();
          tChart1.Draw();
            Rectangle rect = new Rectangle();
            rect = tChart1.Chart.ChartRect;
            g.Pen.Color = tChart1.Axes.Left.AxisPen.Color;
            g.VerticalLine(rect.Right,rect.Top,rect.Bottom);
I hope that will helps.
Pradip
Post by Pradip » Thu Jul 16, 2009 10:12 am
hi Sandra,
thanks for the suggetion.
i had tried your code to resolve this problem, at first it looks ok, but if we zoom to 400 there are still small lines shows on the vertical right axes, which was not accepted at our end.
can you please let us know when you are planning next relaease?
Pradip.
Post by Sandra » Thu Jul 16, 2009 10:51 am
Hello Pradip,
I couldn't reproduce your problem here, please you could send us a simple example project we can run "as-is", to reproduce the problem here? Now, you can attach your project direcly in forums post.
Next TeeChart for .NET 2009 release is due out on week 33 (from 10th to 16th August). However, we can't promise this issue will be fixed for this release yet. A date for next TeeChart for .NET v3 release hasn't been fixed yet.
Also, we recommend you to be aware at this forum or subscribe to our RSS news feed (http://www.steema.com/news/Steema.xml) for new release announcements and what's fixed on them.
