Custom axis labels
franckgar
Custom axis labels
Post by franckgar » Wed May 06, 2009 2:27 pm
I have a question concerning axis labels : is it possible to keep default axis labels when adding a custom one with the routine
NewAxisItem := Chart.DepthAxis.Items.Add(0.0)
thanks
Franck
Post by Yeray » Wed May 06, 2009 3:22 pm
Hi Franck,
I've tried it and forcing a chart draw before adding the new axis labels, the default labels list isn't overwritten:
  Chart1.AddSeries(TSurfaceSeries.Create(self));
  Chart1[0].FillSampleValues(10);
  Chart1.Chart3DPercent := 100;
  Chart1.Axes.Depth.Visible := true;
  Chart1.Draw;
  Chart1.Axes.Depth.Items.Add(5.5);
franckgar
Post by franckgar » Thu May 07, 2009 7:23 am
In my case, default axis labels are hidden as soon as I had a custom one.
You could reproduce it with the example Axes->Labels->CustomLabels in Tee7New.exe
Franck
NB: I'm working with TeeChart v7.07 (source v7.12)
Post by Yeray » Thu May 07, 2009 8:14 am
Hi Franck,
Here is the code of the Custom Labels demo with two little changes that makes the default labels also visible:
- Chart1.Draw to force the default labels to be drawn before adding the custom ones.
- Commented the line Chart1.Axes.Left.Items.Clear in AddCustomLabels method for not to clean the labels.
var i: Integer;
  Chart1.AddSeries(TLineSeries.Create(self));
  Chart1[0].AddArray([200,0,123,300,260,-100,650,400]);
  Chart1.Draw;
  AddCustomLabels;
Procedure TForm1.AddCustomLabels;
  with Chart1.Axes.Left do
//    Items.Clear;  // remove all custom labels
    // add custom labels
    Items.Add(123,'Hello').Font.Size:=16;
    Items.Add(466,'Good'#13'Bye').Transparent:=False;
    Items.Add(300);
    with Items.Add(-100) do
      Transparent:=False;
      Transparency:=50;
      Color:=clBlue;
Another possibility could be drawing the default labels, save them in an array at OnGetAxisLabels event, and then clean all the labels and add the desired ones as custom labels.
franckgar
Post by franckgar » Thu May 07, 2009 9:43 am
Your first possibility does not work on my side :(
You are working with TeeChart v8.xx ?
The second works ... but it is not very practical
Franck
Post by Yeray » Thu May 07, 2009 10:44 am
Hi Franck,
Yes, excuse me. I was making tests with TeeChart 8.04 and I've just seen that with v7 the easiest solutions doesn't work. So with v7 I can only think in the saving to table solution.
If you find problems implementing it, please don't hesitate to let us know.
franckgar
Post by franckgar » Thu May 07, 2009 11:59 am
thanks for your help
Franck
