Drawing on Chart
McMClark
Drawing on Chart
Post by McMClark » Wed Jun 18, 2008 8:10 pm
I would like to enable a user too highlight a part of a graph by draw a box or circle around a section of the chart. I have tried to use the rectangle tool but at runtime the only effect I get is to in act the zoom feature. If the rectangle is the right tool then how do I enable it? I have also tried the annotation tool but I can not enact it.
Post by Narcís » Thu Jun 19, 2008 9:01 am
Hi McMClark,
I've just replied to the thread you posted in the ActiveX forum:
http://www.teechart.net/support/viewtop ... 1566#31566
Same idea applies to the VCL version.
McMClark
Post by McMClark » Fri Jun 20, 2008 2:59 pm
Thank you for your reply. The code does draw the on the canvas but the drawing does not persist. How do I get it to stay after the user finishes drawing?
Post by Yeray » Mon Jun 23, 2008 8:57 am
Hi McMClark,
One solution could be drawing a Shape series instead of a canvas rectangle in OnMouseUp event:
var
  Form1: TForm1;
  X0, X1, Y0, Y1: Integer;
implementation
{$R *.dfm}
    X0 := -1;
    Y0 := -1;
    Chart1.Zoom.Allow := false;
    Chart1.View3D := false;
  Y: Integer);
  X1 := X;
  Y1 := Y;
  If (X0 <> -1) And (Y0 <> -1) Then
    Chart1.Canvas.Brush.Style := bsClear;
    Chart1.Canvas.Pen.Color := clBlack;
    Chart1.Canvas.Rectangle(X0, Y0, X1, Y1);
    Chart1.Draw;
  End;
  X0 := X;
  Y0 := Y;
procedure TForm1.Chart1MouseUp(Sender: TObject; Button: TMouseButton;
var RectSeries: TChartShape;
    RectSeries := TChartShape.Create(Self);
    Chart1.AddSeries(RectSeries);
    with (Chart1.Axes) do
      RectSeries.Style := chasRectangle;
      RectSeries.X0 := Bottom.CalcPosPoint(X0);
      RectSeries.Y0 := Left.CalcPosPoint(Y0);
      RectSeries.X1 := Bottom.CalcPosPoint(X1);
      RectSeries.Y1 := Left.CalcPosPoint(Y1);
  End;
  X0 := -1;
  Y0 := -1;
xxxxxx
Post by xxxxxx » Wed Jun 25, 2008 3:32 pm
Since using TeeChart Standard I used to utilize TChart.OnAfterDraw for such persistent drawings. Isn't it not bad?
Regards, Alexander
TeeChart Pro v8.05, Delphi 5 & Turbo Delphi Professional for Win32., Delphi & C++Builder 2009
Post by Narcís » Thu Jun 26, 2008 7:59 am
Hi Alexander,
No, using OnAfterDraw event is a good option for custom drawing on the chart.
