Series Transparency setting is ignored when Exporting
Kevin
Post by Kevin » Mon Jun 16, 2008 9:07 am
When exporting a chart to an image (e.g. to PNG, JPEG) the series Transparency setting is ignored. The series are output with no transparency i.e. opaque. This is with TeeChart 8.02.
I have tried various series types including bubble and gantt with no success.
Is there a way to get transparency to work when exporting?
Post by Narcís » Mon Jun 16, 2008 9:23 am
Hi Kevin,
Yes, you can use Bitmap exporting for transparency. JPEG export doesn't support it.
Kevin
Post by Kevin » Mon Jun 16, 2008 9:30 am
It seems that Bitmap is the only export format that supports Transparency. Is that correct?
Why can't other formats support transparency? e.g. PNG
Post by Pep » Mon Jun 23, 2008 11:52 am
Hi Kevin,
yes, export to PNG also keeps the transparency applied.
Janusz_Cichocki
TRANSPARENCY ANS EXPORT
Post by Janusz_Cichocki » Thu Jul 03, 2008 8:59 am
I used Teechart v. 7.0 (Delphi 7.0). When exporting BMP it was OK.
with Teechart v. 8.02 (Delphi 7.0) is doesn't work. Transparency is only on the screen. After export to BMP format there is no tranparency.
What has changed ?
Janusz
Post by Narcís » Thu Jul 03, 2008 9:10 am
Hi Janusz,
This works fine for me here using v8.03 release candidate. I've just sent you the URL to download it. Could you please check if this works fine at your end?
Janusz_Cichocki
transparency in v.8.03
Post by Janusz_Cichocki » Thu Jul 03, 2008 11:56 am
version 8.03.11357
Series1 : TWindRoseSeries
I save screen using :
Chart1.SaveToBmpFile (Name)
There is no tranparency in BMP file :(
(Print Screen works OK)
Janusz
Post by Narcís » Thu Jul 03, 2008 12:47 pm
Hi Janusz,
I could reproduce the problem here, I'll add it to the defect list to be reviewed. I've checked that using code above doesn't work in v7 either.
  Chart1.SaveToBitmapFile('c:\temp\wr.bmp');
Anyway, you can use code below, I've checked that this exports a bitmap with transparency.
uses TeeBMPOptions;
var tmp: TBMPExportFormat;
  tmp:= TBMPExportFormat.Create;
  tmp.Panel:=Chart1;
  tmp.SaveToFile('c:\temp\Chart1BMP.' + tmp.FileExtension);
  //Chart1.SaveToBitmapFile('c:\temp\wr.bmp');
Janusz_Cichocki
transparency in export
Post by Janusz_Cichocki » Thu Jul 03, 2008 4:12 pm
I am so glad. Now it works prefect. I have checked out PCX format
and it keeps transparency too ! Thank you for quick answer
Janusz
