TLineSeries and points
Andrew
Post by Andrew » Tue May 11, 2004 2:08 am
Is there any way to turn on points for just a few values, rather than the whole series? I want a certain section of my chart to stand out. Or how about changing the line type for a particular section of points?
Cheers
Andrew
Marjan
Post by Marjan » Tue May 11, 2004 12:15 pm
Hi, Andrew.
Perhaps you could use line series OnGetPointerStyle event for filtering. The following code works fine:
  line1.FillSampleValues(20);
  line1.Pointer.Visible := True;
function TForm1.line1GetPointerStyle(Sender: TChartSeries;
  ValueIndex: Integer): TSeriesPointerStyle;
  // show 2nd and 13th point pointer only
  if (ValueIndex = 1) or (ValueIndex = 12) then Result := psCircle
  else Result := psSmallDot;
Marjan Slatinek,
