How to add a series without changing the Axis scale?
I have a TFastLineSeries in a TChart. The BottomAxis is set to Automatic. I wanted to add a TGanttSeries to the chart without modifying the scale of the bottom axis even it is set to Automatic. Is there a way of doing this? At the moment, every time I add a Ganttseries, the BottomAxis changes because the BottomAxis is set to Automatic.
-Bill
-Bill
- Site Admin
- Contact:
Hi Bill,
This is most likely because TFastLineSeries use values from double x values while TGanttSeries' x values are TDateTime, which actually are doubles as well but start at higher values. That may be the reason why your bottom axis scale is increased. To avoid this, if, for example your TFastLineSeries has 25 x values (from 0 to 24) you should also add TGanttSeries values in this x range, a practical example:
For more information on how TDateTime values work please read TDateTime entry in Delphi's help or read it here.
var i: Integer;
for i:=0 to 25 do
Series1.AddXY(i,i);
var tmpGantt: TGanttSeries;
i: Integer;
tmpGantt:=TGanttSeries.Create(self);
Chart1.AddSeries(tmpGantt);
tmpGantt.AddGantt(0,5, 0, '');
tmpGantt.AddGantt(3,8, 5, '');
tmpGantt.AddGantt(7,15, 10, '');
Thanks for the fast reply. My question is actually a general one. Is there a way to remove a series from Axis.Automatic action. My GanttSeries is out side the range of the Chart and FastLineSeries, however, I don't want the chart to change scale to reflect that. I only wanted the automatic feature to be applied to FastLine. For example, each series has a ShowInLegend option. Is there an option for a series NOT to be included in Axis.Automatic calculation?
-Bill
-Bill
- Site Admin
- Contact:
Hi Bill,
Ok, you can achieve what you request associating the gantt series to a horizontal custom axis, instead of the default bottom axis, and making it not visible. For more information on how to use axes please read Tutorial 4 - Axis Control.
Thanks for the advice. I've tried it and found a "bug"? with MasterAxis.
Please see the following code
Chart1->LeftAxis->Automatic = 1;
pAxis = new TChartAxis(Chart1);
pAxis->Horizontal = 1;
pAxis->Automatic = 0;
pAxis->Visible = 0;
Series2->CustomHorizAxis = pAxis;
Series2->AddXY(-10, -10, "", clRed);
Series2->AddXY(0, -10, "", clRed);
Series2->AddXY(0, -20, "", clRed);
Series2->AddXY(20, -20, "", clRed);
for(int i = 0; i < 101; i++)
Series1->AddXY(i, - i * i / 100.0, "", clRed);
pAxis->MasterAxis = Chart1->BottomAxis;
When I move the chart by right mouse dragging, if I move vertically, Series2 would not show up, Series2 will show if I drag horizontally.
Am I doing something wrong?
pAxis->Visible = 0;
- Site Admin
- Contact:
Hi BE,
First of all please notice that you should populate Gantt series using AddGantt(StartDate, EndDate, YValue). Also please notice that, as said in the documentation, MasterAxis is an internal property:
property MasterAxis: TChartAxis;
Unit
TeEngine
Description
Internal property. The current behaviour might change in future versions.
When an axis has the MasterAxis property set to another axis, when the other axis changes its minimum or maximum values (due to zoom or scroll), our axis gets the same minimum and maximum values.
MasterAxis property can be used to synchronize axes scales automatically without having to do this by code:
Old:
New:
Having said that, this works fine for me here using TeeChart Pro v8. Which TeeChart version are you using? The behaviour you describe happens when MasterAxis is not being used. You could also try this:
Unit
TeEngine
Description
Old:
Chart1.CustomAxes[3].SetMinMax( Chart1.Axes.Left.Minimum, Chart1.Axes.Left.Maximum );
Chart1.CustomAxes[3].MasterAxis := Chart1.Axes.Left;
Chart1->CustomAxes->Items[0]->MasterAxis = Chart1->Axes->Bottom;
Ok, I think I know where my problem is now. It is a general question.
When I do the following;
Chart1->BottomAxis->Automatic = 1;
Series1->AddXY(i, i, "", clRed);
Chart1 Bottom Axis Mininmum is not 0.0 and Max is not 100.0. It is something else. Min is a bit less then 0.0 and Max is a bit more then 100.0.
If I set Series2->CustomAxis to something other than Chart1->BottomAxis and set teh customAxis to MinMax(0, 100), then, Series1 and Seri2 Axes are a bit mis aligned.
__fastcall TForm1::TForm1(TComponent* Owner)
: TForm(Owner)
pAxis->Visible = 0;
pAxis->SetMinMax(Chart1->BottomAxis->Minimum, Chart1->BottomAxis->Maximum);
However, at this point Chart1->BottomAxes are 0.0. How do I get the Ases info at this point so I can aligned the two axes?
: TForm(Owner)
pAxis->Visible = 0;
- Site Admin
- Contact:
Hi BE,
This is most likely because the chart hasn't been drawn yet and therefore axes don't have their values calculated yet. You could do something like this:
Chart1->Draw();
pAxis ->SetMinMax(Chart1->Axes->Bottom->Minimum, Chart1->Axes->Bottom->Maximum);
Tried it. Now when I use debuger, the Chart1->BottomAxis Min and Max are 0.0 and 100.0, but the Axes are still mis aligned for some reason. When I make both Axes visible, it is clear that they are mis aligned. However, when I scroll the chart, they are aligned right a way! There's a diff between what's displayed and what Chart1->Bottomaxis->Min and Mas are! Why is that. What do I have to do to get them aligned at the Chart creation point?
I'm using TeeChart 7.02
- Site Admin
- Contact:
Hi BE,
Won't you have Chart1->Axes->Bottom->MinimumOffset or Chart1->Axes->Bottom->MaximumOffset different from zero either set at design-time or at run-time? You can try adding this:
Also notice that there are much newer versions of TeeChart Pro v7 VCL available at the client download area.
If the problem persists please send us a simple example project we can run "as-is" to reproduce the problem here. You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
Chart1->Axes->Bottom->MinimumOffset=0;
Chart1->Axes->Bottom->MaximumOffset=0;
tried that as well. Got the same result.
If I do the following;
Chart1->Draw();
Chart1->BottomAxis->SetMinMax(Chart1->BottomAxis->Minimum, Chart1->BottomAxis->Maximum);
That gets the Axes aligned.
I will create a sample project and send it to you.
Chart1->Draw();
- Site Admin
- Contact:
Hi BE,
Thanks for the example project. In that case, it works fine synchronizing bottom and custom axes in OnZoom, OnScroll and OnUndoZoom events as shown below. Please also notice that BottomAxis like nomenclature is deprecated and you should better use Axes->Bottom.
: TForm(Owner)
Chart1->LeftAxis->Increment = 100 / 5;
Chart1->BottomAxis->Increment = 100 / 5;
Series1->AddXY(i, -i*i /100.0, "", clRed);
Chart1->BottomAxis->MinimumOffset = 0;
Chart1->BottomAxis->MaximumOffset = 0;
Chart1->Draw();
TChartAxis * pAxis = new TChartAxis(Chart1);
pAxis->Visible = 1;
Series2->AddXY(20, -40, "", clRed);
// Chart1->BottomAxis->SetMinMax(Chart1->BottomAxis->Minimum, Chart1->BottomAxis->Maximum);
//pAxis->SetMinMax(Chart1->BottomAxis->Minimum, Chart1->BottomAxis->Maximum);
SynchronizeAxes();
void TForm1::SynchronizeAxes()
Chart1->CustomAxes->Items[0]->SetMinMax(Chart1->Axes->Bottom->Minimum, Chart1->Axes->Bottom->Maximum);
void __fastcall TForm1::Chart1Zoom(TObject *Sender)
SynchronizeAxes();
void __fastcall TForm1::Chart1UndoZoom(TObject *Sender)
SynchronizeAxes();
void __fastcall TForm1::Chart1Scroll(TObject *Sender)
SynchronizeAxes();
