At the same time
Kai
At the same time
Post by Kai » Mon Apr 05, 2004 11:51 pm
Can you run TeeChart 6 and TeeChart 7 at the same time in Delphi 6 Pro?
- or do you have to uninstall TeeChart 6 in order to install TeeChart 7?
thanks
Marjan
Post by Marjan » Tue Apr 06, 2004 7:14 am
Hi, Kai.
Yes, you can have TeeChart v6 and TeeChart v7 installed at teh same time (separate directories though). Then you can switch between two versions by changing TeeChart path in Delphi search path and disabling/enabling different version design time packages.
The only thing you can't have is use both versions at the same time in the same application.
Marjan Slatinek,
