How to disable zoom when Ctrl is pressed ?
bsonnino
Post by bsonnino » Tue Mar 23, 2004 11:14 am
I have a chart with Horizontal zoom enabled, but I want to do a special
funcion when the Ctrl key is pressed: I want the zoom lines to be drawn,
then I want to clear all points in the selected interval (this is done
setting color clNone to all points), but I dont want the chart to be zoomed.
When Ctrl is not pressed, I want the default behavior.
Is there a way to do it ?
Bruno
Post by Pep » Thu Apr 15, 2004 2:37 pm
Hi Bruno,
a trick could be to check if Ctrl key is pressed in the OnMouseDown event :
  {Check if CONTROL key is down}
  Chart1.Zoom.Allow := (HiWord(GetKeyState(VK_CONTROL)) <> 0);
