Log problems with bar chart
Cyionics
Post by Cyionics » Wed Mar 15, 2006 8:50 am
Hi
I have found an issue with log display using bars
we use numbers like 1 e -9, 1 e-10 etc
This display fine in a line or point chart but in a bar chart they are displayed incorrectly in log Y axis if the values are less than 1.
Peter
Post by Narcís » Wed Mar 15, 2006 10:08 am
Hi Cyionics,
Can you please drop a TChart and a TButton in a form and test the code below? Does it reproduces the issue you report? I mean, the issue you are reporting is that the left axis is not properly scaled when using a TBarSeries?
var i: Integer;
  Chart1.AddSeries(TBarSeries.Create(self));
  for i:=0 to 10 do Chart1[0].Add(random);
  Chart1.Axes.Left.Logarithmic:=true;
  Chart1[0].ValueFormat:='#.0 "x10" E+0';
var tmp: TChartSeries;
  tmp:=Chart1[0];
  if tmp is TBarSeries then ChangeSeriesType(tmp, TLineSeries)
  else ChangeSeriesType(tmp, TBarSeries);
Cyionics
log display in bar
Post by Cyionics » Wed Mar 15, 2006 11:24 am
Hi
Yes that certainly looks like the issue
Peter
Post by Narcís » Wed Mar 15, 2006 12:12 pm
Hi Peter,
Thanks for confirming. I've added the issue (TV52011316) to our defect list to be fixed for future releases. In the meantime, you can try solving that problem by manually setting left axis minimum and maximum values using Chart1.Axes.Left.SetMinMax method.
