TBarSeries - Problems on accessing BarChart Marks
holgerBig
Post by holgerBig » Wed Feb 19, 2020 10:39 am
I have a chart with two BarSeries. Here I would like to display the Bar-Marks at a different position. When changing the position I always get exceptions at different positions.
The problem is that the BarSeries are well drawn, but some entries in the Marks.Positions-List are null. Then it crashes.
What is the problem?
Creating the series
procedure TForm1.Button3Click(Sender: TObject);
var i, val : integer
  for  i := 0 to 30 do
    val := random(50)+50;
    chart1.Series[0].AddXY(i+1, val, format('Mark: %d', [i+1]), clGreen);
    chart1.Series[1].AddXY(i+1, val, format('Mark: %d', [i+1]), clRed);
    dt := dt + 1;
  Chart1.Draw();
  PlaceMarks();
... and change the mark position
procedure TForm1.PlaceMarks2;
var s, i, w1, w2, w3, tmpSize: Integer;
  Chart1.Draw;
  for s:=0 to Chart1.SeriesCount-1 do
    if Chart1[s] is TBarSeries then
      with Chart1[s] as TBarSeries do
        for i:=0 to Count-1 do
          with Marks.Positions[i] do
            if (marks.Visible = true) then
              Custom:=true;     // => Exception !!!! (Marks.Position[i] is null)
              Marks.Angle := 90;
              LeftTop.X := LeftTop.X;
Re: TBarSeries - Problems on accessing BarChart Marks
Post by Marc » Wed Feb 19, 2020 1:14 pm
You need to set:
  chart1.Series[0].Marks.AutoPosition := False;
  chart1.Series[1].Marks.AutoPosition := False;
otherwise TeeChart will not create/render Marks at locations that are obscured by others.
