formatting axis labels
JimR
Post by JimR » Mon Oct 16, 2017 8:42 pm
In the TeeChart Pro v2017 VCL/FMX library reference and user guide it shows using an exponent as follows:
TChart1.Axis.Left.Labels.Exponent:=True ;
TChart1.Axis.Left.Labels.ValueFormat:="00e-0" ;
However, that variable does not seem to exist. I did find that I could use the following to provide the format:
Chart.Axes.Bottom.AxisValuesFormat := s;
Chart.Axes.bottom.LabelsExponent := true;
Is that the correct way? It "works" except the label is too high so that the scale labels drop down and covers part of the title for the bottom axis as shown in the attachment. Is there a way to fix this? Looks rather ugly!
Is my copy of the User Guide out of date? It does say v2017.
Screen Shot 10-16-17 at 04.28 PM.PNG (2.2 KiB) Viewed 8823 times
Re: formatting axis labels
Post by Yeray » Tue Oct 17, 2017 8:26 am
I've reproduced the problem so I've added it to the public tracker here:
http://bugs.teechart.net/show_bug.cgi?id=1928
JimR
Post by JimR » Thu Oct 26, 2017 8:52 pm
One more problem: when using an exponent the axis labels do not rotate. At 90 degrees the axis moves up to allow the space for rotated axis labels but they stay at 0 degrees.
Post by Yeray » Fri Oct 27, 2017 9:48 am
JimR wrote:One more problem: when using an exponent the axis labels do not rotate. At 90 degrees the axis moves up to allow the space for rotated axis labels but they stay at 0 degrees.
That's right. As they are drawn, the labels can't be rotated when using LabelsExponent. I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1934
