2014.11.140409
In the attached demo, I have code that use to work (I believe Steema support provided similar code) to draw selected labels on the bottom axis in red. This one should draw every other label in red. It doesn't work in the latest version.
How should this be coded?
Ed Dressel
Drawing bottom axis label in red
- Advanced
- Draw Axis Label.zip
- (2.2 KiB) Downloaded 578 times
Re: Drawing bottom axis label in red
Hi Ed,
Instead of modifying the Canvas Font, you could modify the Bottom Axis LabelsFont in the OnDrawLabel event, making sure you also handle the "else" situation setting the default properties to the LabelsFont. Ie:
As an alternative, the latest TeeChart versions allow you yo to directly set the LabelsList in your Bottom Axis, instead of having to use the OnDrawLabel event. Ie:
if (lIdx > -1) and (FDrawRedIndexes.IndexOf(TObject(lIdx)) > -1) then
{lChart.Canvas.Font.Color := clRed;
lChart.Canvas.Font.Style := [fsBold];}
lChart.Axes.Bottom.LabelsFont.Color:=clRed;
lChart.Axes.Bottom.LabelsFont.Style:=[fsBold];
end
lChart.Axes.Bottom.LabelsFont.Color:=clBlack;
lChart.Axes.Bottom.LabelsFont.Style:=[];
constructor TForm1.Create(aOwner: TComponent);
var
lValue: Double;
I, J: Integer;
lIdx: Integer;
aX: Integer;
lCalcXPos: Integer;
lMinOffBy: Integer;
lOffBy: Integer;
lSrs: TChartSeries;
inherited;
Caption := TeeMsg_Version;
FDrawRedIndexes := TList.Create;
SEries1.Clear;
lValue := 1000.0;
for I := 0 to 19 do
Series1.Add(lValue);
lValue := lValue * 1.03;
if (I mod 2) = 0 then
FDrawRedIndexes.Add(TObject(I));
//Chart1.BottomAxis.OnDrawLabel := ChartBottomAxisDrawLabel;
Chart1.Draw;
with Chart1.Axes.Bottom.Items do
Automatic:=false;
for I := 0 to Count-1 do
lSrs := Chart1.Series[0];
lIdx := -1;
aX := Item[I].LabelPos;
lMinOffBy := MaxInt;
for J := lSrs.Count - 1 downto 0 do
lCalcXPos := lSrs.CalcXPos(J);
lOffBy := abs(aX - lCalcXPos);
if (lOffBy < lMinOffBy) then
lIdx := J;
lMinOffBy := lOffBy;
Item[I].Format.Font.Color := clRed;
Item[I].Format.Font.Style := [fsBold];
