In the demo using the link, I can click and drag the mouse left or right and it will normally highlight a x-range of the grid -- a color band highlights the selected items.
1. But.... sometimes it doesn't work (this it is highlighted in the MP4 video in the download). I can click and drag and the color band's start and end value seem to be the same. It seems that this occurs if I click on the very left side of a bar.
http://www.TBInc.com/misc/SelectionPoint3a.zip
I can't figure out how to fix this behavior.
2. Also, when the band is drawn, it is drawn from the left edge of the bar. How can I make the band start in the middle of the bar?
Thank you,
Ed Dressel
Using a Color Band to select a range of bars
- Advanced
Re: Using a Color Band to select a range of bars
Hi Ed,
This part is the easy one. Some events seem to be interfering here. You can fix it disabling the AllowDrag property on all the dependant tools:TestAlways wrote:1. But.... sometimes it doesn't work (this it is highlighted in the MP4 video in the download). I can click and drag and the color band's start and end value seem to be the same. It seems that this occurs if I click on the very left side of a bar.
cbHighlight.StartLine.AllowDrag:=false;
cbHighlight.EndLine.AllowDrag:=false;
cbHighlight.AllowDrag:=false;
This will be more difficult. This means to change how the TColorBandTool is being drawn and I haven't found a way to override the needed functions so I can only think on modifying the TColorBandTool Drawing method on TeeChart sources or to skip using this tool and draw what you want in the OnBeforeDrawSeries event.TestAlways wrote:2. Also, when the band is drawn, it is drawn from the left edge of the bar. How can I make the band start in the middle of the bar?
