Strange Behavior of the TColorBandTool
I have strange bug in the new release of the TeeChart: (using CBuilderXE5)
If I put TColorBandTool to the chart, then compile, it works well.
But if I'll view the Form as Text, then again as Form, there will be visible in Tools of the Chart 3 ChartTools: one band and two additional TColorLineTools.
If I'do this again (view Form as Text then view as Form) I'get additional 2 ColorLines, and so on.
Additional TColorLines are ghost.
For this reason I have on my application AV and can't use TColorBand at all.
Withis the Test.zip it is possible to see ghost ColorLines.
- test.zip
- (48.54 KiB) Downloaded 756 times
With best regards
Vladimir
Vladimir
Re: Strange Behavior of the TColorBandTool
This bug is connected by some way with the new AxisID, I don't know why...
With best regards
Vladimir
Vladimir
Hi Vladimir,
I've added it to the tracker:
http://bugs.teechart.net/show_bug.cgi?id=610
Feel free to add your mail account to the CC list so you can be automatically informed when an update will arrive.
- Site Admin
- Contact:
Hi Vladimir,
This issue has just been fixed for the next maintenance release, see David Berneda's comment.
Hi, Narcis
Can you give a peace of code (TColorBandTool) to fix the problem, as next maintenance release will not be soon, I think.
With best regards
Vladimir
Vladimir
- Site Admin
- Contact:
Hi Vladimir,
Yes, I sent you TeeTools.pas with the fix.
Dear Narcís
I got very strange error:
Cant recompile with new TeeTools.pas:
Cannot recompile Delphi package: TeePro919.dpk
Embarcadero Delphi for Win32 compiler version 26.0
Copyright (c) 1983,2013 Embarcadero Technologies, Inc.
VCLTee.TeeTools.pas(3742) Error: E2003 Undeclared identifier: 'InternalSetAxis'
VCLTee.TeeCursorEdit.pas(509) Fatal: F2063 Could not compile used unit 'VCLTee.TeeTools.pas'
EXCEPTION:
Compilation aborted.
EXCEPTION:
With best regards
Vladimir
Vladimir
- Site Admin
- Contact:
Hi Vladimir,
I sent you a test source code installer with all up to date units.
Hello Narcís,
I do have the same problem.
It took me quite a while to detect for the reason why my exe code was growing and growing.
Can I get a bugfix as soon as possible please? I have to deliver my software.
I'm using VCL Pro source code 2014 with XE4
Uli
Uli
- Site Admin
- Contact:
Hi Uli,
Just sent you an email with the information to download it.
I have not yet updated to the 2014 release. I am however, making extensive use of Color Band because they're cool. Do you guys have a recommendation whether one should update or wait for the next release?
By the way, I am also a sourcecode customer but I honestly have no clue how it should be used it. I cannot find any documentation on the subject.
Best regards.
Best regards.
Dear Narcís,
I have tried to install the version you have sent but have simply failed. I have sent you also a private message about this.
So right now I have re-installed the source of Feb. 24 again and switched back to GDI.
It seems that GDI+ has some problems, see also TNumericGauge http://www.teechart.net/support/viewtop ... =3&t=14743
- Uli
- Uli
- Site Admin
- Contact:
Hi Uli,
That's an error with TAskLanguage.OKBtnClick method at TeeTranslateEditor.pas. You can comment out the code in this method. It has been fixed for future releases as well.
