Files in TeeChart Pro 2012 Full Source Code\Sources\VCL not
WilliEbert
Post by WilliEbert » Thu Nov 15, 2012 8:30 pm
your source code installer from ver v2012.07.121105 VCL had not copied the actual files, like VCLTee.Chart.pas, in the folder ..\TeeChart Pro 2012 Full Source Code\Sources\VCL. In this folder the file version is still v2012.05
Your sincerly
Willi
Re: Files in TeeChart Pro 2012 Full Source Code\Sources\VCL not
Post by Yeray » Fri Nov 16, 2012 3:48 pm
Hi Willi,
The source code installer doesn't create the VCL folder. It is created by TeeRecompile tool.
Please, remove that folder and run TeeRecompile again. Also, make sure to run TeeRecompile with high privileges.
WilliEbert
Post by WilliEbert » Fri Nov 16, 2012 4:02 pm
Hello Yeray,
thank you very much this was it.
Your sincerely
Willi Ebert
