Printing issue with TeeChart Pro 2011 for Delphi XE2
Hi.
I encountered an issue whith the fonts when printing with TeeChart Pro 2011 for Delphi XE2.
With Delphi 2010 the printed export looks as expected:
With Delphi XE2 the fonts of the legend and the hints looks very strange:
I use TChart.PrintPartial() for printing.
Is this a known issue?
Is there a fix or workaround for this?
Thanks for your help!
- Site Admin
- Contact:
Re: Printing issue with TeeChart Pro 2011 for Delphi XE2
Hi marder,
This works fine for me here with Delphi XE2 using this code:
Which TeeChart version are you using? Does this occur with different printers?
uses VCLTee.Series, VCL.Printers;
procedure TForm2.FormCreate(Sender: TObject);
Chart1.AddSeries(TPieSeries.Create(Self)).FillSampleValues;
Chart1.Legend.Alignment:=laBottom
procedure TForm2.Button1Click(Sender: TObject);
Printer.Orientation:=poLandscape;
Printer.BeginDoc;
Chart1.PrintPartial(Rect(0,0,Printer.PageWidth,Printer.PageHeight));
Printer.EndDoc;
Hi Narcis,
I tried the code you send me, but this however leads to the same result.
When I use the code in a simple sample project with chart and pie series default settings, all works as expected
Anyway, the printing works correctly with Delphi 2010.
I will try to build a sample project including my settings were this issue occurs.
Contact you soon...
Contact you soon...
P.S.: This issue is not specific for one printer. I tried with several printers.
- Site Admin
- Contact:
Hi marder,
Thanks for the feedback.When I use the code in a simple sample project with chart and pie series default settings, all works as expected
Yes, please, that will help.I will try to build a sample project including my settings were this issue occurs.
Hi Narcis.
I found the reason that causes this issue!
I am using TGDIPlusCanvas form unit VCLTee.TeeGDIPlus as Canvas for the chart.
Please add
Note: I use TGDIPlusCanvas to prevent an issue with the Anti-Alias tools in TeeChart Pro 2011 which I reported before
(See: http://www.teechart.net/support/viewtop ... f=3&t=9180)
So what should I do now?
Do I have to decide between fancy chart in GUI or fancy chart in printed export
Please add
to the OnCreate event of the main form to see this issue.
Chart1.Canvas := TGDIPlusCanvas.Create;
- Site Admin
- Contact:
Hi marder,
I don't get strange fonts as you did using the code you posted. What about antialiasing GDI+ canvas and font?
If the problem persists could you please let us know the exact TeeChart version you are using and attach a simple example project we can run "as-is" to reproduce the problem here?
var g: TGDIPlusCanvas;
Chart1.Legend.Alignment:=laBottom;
g:=TGDIPlusCanvas.Create;
g.AntiAlias:=True;
g.AntiAliasText:=gpfBest;
Chart1.Canvas := g;
Dear Narcis.
And here the printed chart with gdi+ canvas:
The printed font in the hints and legend looks quite strange.
I see no effect when I set them again after creation.
Release Notes 17th November 2011
TeeChart VCL version 2011
Build 2011.04.41118
http://download.jam-software.de/treesiz ... tPrint.zip
Thanks for your help and best regards.
Please take a look at the printed chart with common canvas:I don't get strange fonts as you did using the code you posted.
In my version of TeeChart Pro "AntiAlias:=True" and "AntiAliasText:=gpfBest" are the default settings of TGDIPlusCanvas.What about antialiasing GDI+ canvas and font?
From the "Release.txt":If the problem persists could you please let us know the exact TeeChart version you are using
Build 2011.04.41118
Please find a sample project hereand attach a simple example project we can run "as-is" to reproduce the problem here
- Site Admin
- Contact:
Dear marder,
Neither the images nor the examples project links are working. Could you please check them or attach the files in the forums?
Dear Narcis.
Sorry, the links are currently not available.
I attached the files to this post.
Thanks and best regards.
- TestChartPrint.zip
- pie chart print demo project
- (82.19 KiB) Downloaded 739 times
- pie chart with gdi+ canvas
- pie_chart_print_with_gdi_plus_canvas.png (72.93 KiB) Viewed 20060 times
- pie chart with common canvas
- pie_chart_print_with_common_canvas.png (76.7 KiB) Viewed 20059 times
- Site Admin
- Contact:
Hi marder,
Thanks for the files. I see, fonts could be much better with PrintPartial. I have added the issue (TV52016107) to the bug list. In the meantime, I recommend you to use StretchDraw as explained here. I checked this works fine with your project.
Dear Narcis.
Using StrechDraw() with a bitmap seems to work better.
I'm currently trying to include this to my existing code, which is not that easy since there is some other stuff printed beside the chart.
I will contact you again if I need additional help.
Dear Narcis.
Ok, I managed to bring text and chart (bitmap) together on one printed export.
Anyway, when using your workaround the resolution of the printed export is not as good as when using PrintPartial.
This is because, when generating the bitmap, we use the dimensions of the TChart component. For printing the dimensions of the printer are used, since we want to use the whole page.
In case of using the dimensions of the printer also for exporting the bitmap, the hints and the legend are shown unreadable small (See attachment).
Best regards.
Best regards.
- pie chart with unreadable small hint and legend
- pie_print_with_too_small_hint_and_legend.png (40.7 KiB) Viewed 20032 times
Hi marder,
You could try to increase the marks and legend fonts before generating the image to be printed.
I'd also suggest you to take a look at the printing better article here
We've just checked it with the actual v2012.07 and the example you posted above now seems to produce nice fonts, using PrintPartial and GDI+
Could you please give it a try?
