Marks just for individual points along a series
Andreas iCD
Post by Andreas iCD » Fri Dec 02, 2011 8:26 am
I tried to use the marks-feature to label just one or a few points of the complete series (TPointSeries or TLineSeries). The other points should be left unlabeled. However, my experiments with the series.marks object did not seem to be very successful. I tried the following code (using TeeChart 2010):
  Series:=TLineSeries(Chart1.SeriesList[0]);
  Series.Clear;
  Series.Pen.Visible:=true;
  Series.Pointer.Visible:=true;
  for i := 0 to 10 do
    Series.AddXY(i,random(10),'');
    if i=3 then
      Series.ValueMarkText[i]:='Special Point'
      Series.ValueMarkText[i]:='';
  series.Marks.Visible:=true;
  Series.Marks.OnTop:=true;
As expected, the point of index 3 was labeled with "Special Point", but all other points were marked as well: their label contains the current y-value of the point, although I set ValueMarkText:='' (empty string). Has anybody any idea how to solve this problem? Im sure, there is a very simple solution for this, but I couldn't find the answer from online help or forum posts.
ulibru
Re: Marks just for individual points along a series
Post by ulibru » Fri Dec 02, 2011 9:12 am
Have you tried the OnGetMarkText event of a series?
Something like:
procedure TMainForm.Series1GetMarkText(Sender: TChartSeries;
  ValueIndex: Integer; var MarkText: string);
  if ValueIndex=3 then
    MarkText := 'Hello'
    MarkText := '';
Regards, Uli
Andreas iCD
Post by Andreas iCD » Fri Dec 02, 2011 10:00 am
Thanks a lot!
this is exactly, what I've been looking for and it works fine!
Andreas
