How to use Teegdiplus
Werner
Post by Werner » Wed Oct 20, 2010 10:13 am
I am using Teechart V8.07. How can I activate the gdiplus function ?
with best regards
Werner
Re: How to use Teegdiplus
Post by Narcís » Wed Oct 20, 2010 10:28 am
Hi Werner,
There's an example at the new features demo at All Features\Welcome!\3D Canvas\GDI+ Canvas, the demo is available at TeeChart's program group.
Werner
Post by Werner » Wed Oct 20, 2010 12:04 pm
Dear Narcis,
I have tried it, but I don't succeed at least.
In the function TGDIPLUSCanvas.GDPIColor I get a runtime error out of range.
I have modified with {$R-}, now the error disappeared, but the colors are not correct.
I have it tried on Xp and Win 7
with best regards
Werner
function TGDIPlusCanvas.GDIPColor(AColor:TColor):{$IFDEF CLR}Color{$ELSE}TColor{$ENDIF};
AColor:=ColorToRGB(AColor);
{$IFDEF CLR}
result:=Color.FromArgb(AColor);
{$ELSE}
{$R-}
result:= ( Byte(AColor shr 16) or
(DWORD(Byte(AColor shr 8)) shl GreenShift) or
(DWORD(Byte(AColor)) shl RedShift) or
(DWORD(Transparency) shl AlphaShift));
{R+}
{$ENDIF}
Post by Narcís » Thu Oct 21, 2010 10:59 am
Dear Werner,
Can you please attach a simple example project or code snippet we can run "as-is" to reproduce the problem here?
Werner
Post by Werner » Mon Oct 25, 2010 7:23 am
Dear Narcis,
I have uploaded the zip file TestGDIPlus.
Please press the load button and load Dadmix.01z, the chart will be loaded. Zoom rectangle will be shown in case of zoom.
After pressing the gdi+ button the chart change the color to red only and the zoom rectangle will be not shown anymore.
with best regards
Werner
Post by Narcís » Mon Oct 25, 2010 11:01 am
Hi Werner,
Thanks for the example code. I think I could narrow down the issue to this code:
uses TeeGDIPlus, TeeSurfa;
var g :TGDIPlusCanvas;
  g:=TGDIPlusCanvas.Create;
  Chart1.Canvas:=g;
  Chart1.AddSeries(TSurfaceSeries.Create(Self)).FillSampleValues;
  (Chart1[0] as TSurfaceSeries).FastBrush:=True;
Setting FastBrush to False works fine. I've checked this also works fine in your example. Anyway, I have added the defect (TV52015236) to the bug list to be fixed for future releases.
The zoom pen issue already works fine using TeeChart Pro 2010 VCL. GDI+ canvas has been improved substantially in 2010 version.
