MultiLanguage problems
ramdevteam
Post by ramdevteam » Thu Aug 20, 2009 10:17 am
I developp with BDS2006. for french.
In my app (VCL.NET), I want french screen but all teechart screens are in english.
I try code found in all features\..\Multilangage but without success.
At runtime, form are in english.
In my frame, I have drop an TchartEditor component
For Tchart component, I create it at runtime :
I use :
uses
 Teeconst, TeeProcCo, TeeTranslate,  TeeFrench,
  chart1 := Tchart.create(self);
  charteditor1.chart := chart1;
  TeeSetFrench;
I have missed something ?
(Teechart 8.05 with fullcode)
Re: MultiLanguage problems
Post by Yeray » Fri Aug 21, 2009 8:17 am
Bonjour ramdevteam,
Could you please try the following example? This seems to work fine here:
uses Chart, TeeEdit, TeeTranslate, TeeFrench;
var ChartEditor1: TChartEditor;
    Chart1: TChart;
  Chart1 := TChart.Create(self);
  Chart1.Parent := Form1;
  ChartEditor1 := TChartEditor.Create(self);
  TeeSetFrench;
  ChartEditor1.Chart := Chart1;
  ChartEditor1.Execute;
ramdevteam
Post by ramdevteam » Fri Aug 21, 2009 9:12 am
Thanks for your answer.
I've try but
TchartEditor is always in english.
My complete code :
unit testCodeU;
interface
uses
  Dialogs, Chart, TeeEdit, TeeTranslate, TeeFrench;
type
  TForm5 = class(TForm)
  private
    { Private declarations }
    Chart1: TChart;
  public
    { Public declarations }
    class procedure Showform;
implementation
{$R *.nfm}
procedure TForm5.FormCreate(Sender: TObject);
  Chart1.Parent := self;
  TeeSetFrench;
class procedure TForm5.Showform;
var
  Form5: Tform5;
   Form5:= Tform5.create(application);
   with Form5 do
   try
     showmodal;
   finally
     release;
end.
The screen is called with :
   Tform5.showform;
Best regards
ramdevteam
Post by ramdevteam » Fri Aug 21, 2009 9:27 am
I have retry with 2 new projects :
- first project : VCL for win32 => Your code works fine and ChartEditor is in french
- second project : VCL for NET (like my app) => ChartEditor stay in english
In the VCL.NET project :
  TeeAskLanguage;
  MessageDlg('TeeLanguageRegistry:' + inttostr(TeeLanguageRegistry), mtWarning, [mbOK], 0);
in the langage list, French is pre-selected
When I clic on OK, the message is "TeeLanguageRegistry:7"
Project reference :
{%DelphiDotNetAssemblyCompiler 'c:\program files\steema software\teechart 8.05 for delphi 2006\delphi10\assemblies\Steema.TeeChart.VCL.dll'}
{%DelphiDotNetAssemblyCompiler 'c:\program files\steema software\teechart 8.05 for delphi 2006\delphi10\assemblies\Steema.TeeChart.VCL.Languages.dll'}
OS: Vista
Post by Narcís » Wed Aug 26, 2009 7:31 am
Hi ramdevteam,
Thanks for the information. I have checked it works fine in VCL for Win32 projects but also checked that it fails in VCL.NET project so I have added the defect (TV52014365) to the bug list to be fixed for next releases.
ramdevteam
Post by ramdevteam » Thu Aug 27, 2009 7:25 am
Do you have a public bug tracking system for viewing bugs status ?
Best Regards
Post by Yeray » Thu Aug 27, 2009 7:55 am
Hi ramdevteam,
No, there is no public bug tracking system. But we try to give the number of the bug labeled in the internal system to the customers sio that they can be aware at the release notes of the versions to see if the bug is expressly fixed.
ramdevteam
Post by ramdevteam » Thu Aug 27, 2009 8:01 am
Ok,
I have see that the other TeeChart component or popup are in english (TeeCommander Hint, Print Popup etc...)
Is it include in this ticket ?
Best Regards
Post by Yeray » Thu Aug 27, 2009 8:19 am
Hi ramdevteam,
The bug ticket says textually:
"Setting a language different than English doesn't work in VCL.NET, code to reproduce:
TeeSetFrench;
I guess that fixing the translation procedure in general should solve the whole translation.
ramdevteam
Post by ramdevteam » Fri Feb 12, 2010 3:44 pm
Have you fixed the bug TV52014365 ?
I haven't see it in the release.txt file of the TeeChart8.06Delphi2006.exe (Build 8.06.60902)
I need to deploy my software, but with teechart english screens, it's not very good for my french customers.
Best Regards
Post by Narcís » Mon Feb 15, 2010 9:39 am
Hi ramdevteam,
No, this is a high-priority item we will try to fix for next versions. We have investigated the issue a little bit but haven't found a solution to it yet.
ramdevteam
Post by ramdevteam » Mon Aug 09, 2010 10:24 am
Have you some news about the bug TV52014365 ?
Best regards.
Post by Yeray » Mon Aug 09, 2010 5:33 pm
Hi ramdevteam,
The (TV52014365) bug has been already fixed. It will be available with the next maintenance release that should be published in the next weeks.
