X-ray
Post
by X-ray » Wed Apr 03, 2024 1:59 pm
We produce graphics like in the attached plot with TChart, where we use a ColorGrid plus 3 Line Series.
Usually we display the Colors of the Color Grid in the Legend. Now we want in addition to show a legend for the 3 Line Series. But when we include the Line Series in the Legend the Color Grid colors are vanishing, see attachment.
How can we have the Color Grid colors Legend AND a Legend for the Line Series?
Thanks and best regards
- Legend1CaptureNew.png (404.6 KiB) Viewed 62695 times
- Legend2Capture.PNG (198.18 KiB) Viewed 62695 times
Post
by Yeray » Thu Apr 04, 2024 7:12 am
When the legend shows the palette, I don't see a lot of space to show any other item. Then, the ExtraLegendTool may be the most appropriate solution for this.
See the example
here.
X-ray
Post
by X-ray » Thu Apr 04, 2024 7:36 am
Hello Yeray,
Thanks for the quick response, that indeed seems to be a way to proceed.
But how can I make sure to just just show the 3 Line Series in THAT extra legend?
Best regards,
Thomas
X-ray
Post
by X-ray » Thu Apr 04, 2024 2:03 pm
To phrase this question differently, how can I explicitly decide in which of both (or more) Legends any Series is shown?
Because Series.ShowInLegend is global for all Legends.
Post
by Yeray » Thu Apr 04, 2024 8:42 pm
You could do something similar to the discussed
here.
uses TeEngine, Chart, Series, TeeSurfa, TeeExtraLegendTool;
type TMyExtraLegendTool=class(TExtraLegendTool)
protected
procedure ChartEvent(AEvent: TChartToolEvent); override;
TLegendAccess=class(TChartLegend);
var Chart1: TChart;
procedure TMyExtraLegendTool.ChartEvent(AEvent: TChartToolEvent);
var i: Integer;
if AEvent=cteAfterDraw then
for i:=0 to ParentChart.SeriesCount-1 do
ParentChart[i].ShowInLegend:=ParentChart[i] is TLineSeries;
if Assigned(ParentChart) and Assigned(Series) then
if Legend.Visible then
TLegendAccess(Legend).CalcRect;
Legend.DrawLegend;
procedure TForm1.Chart1BeforeDrawChart(Sender: TObject);
var i: Integer;
Chart1[i].ShowInLegend:=Chart1[i] is TColorGridSeries;
var i: Integer;
Chart1:=TChart.Create(Self);
with Chart1 do
Parent:=Self;
Align:=alClient;
Color:=clWhite;
Gradient.Visible:=False;
Walls.Back.Color:=clWhite;
View3D:=False;
OnBeforeDrawChart:=Chart1BeforeDrawChart;
with TColorGridSeries(Chart1.AddSeries(TColorGridSeries)) do
Pen.Hide;
FillSampleValues;
for i:=0 to 1 do
with TLineSeries(Chart1.AddSeries(TLineSeries)) do
Pen.Width:=2;
FillSampleValues;
Chart1.Draw;
with TMyExtraLegendTool(Chart1.Tools.Add(TMyExtraLegendTool)) do
Series:=Chart1[1];
Legend.LegendStyle:=lsSeries;
Legend.Left:=Chart1.Legend.Left;
Legend.Top:=Chart1.ChartRect.Top;
- ColorGrid_Line_ExtraLegend.png (41.2 KiB) Viewed 62644 times
X-ray
Post
by X-ray » Fri Apr 05, 2024 9:38 am
Thanks a lot, we are practically there:
- NewCapture.PNG (383.05 KiB) Viewed 62631 times
I am setting the Position in the Create of the form but it looks like I need to update the position of the
extra legend before the painting.
One other quick question, how can I change/influence the texts that are shown in the Extra legend, I'd like to have other text than names of the Series?
Post
by Yeray » Fri Apr 05, 2024 9:55 am
X-ray wrote: ↑Fri Apr 05, 2024 9:38 am
Yes, that's why I called
Draw
before creating the
TExtraLegendTool
at
OnCreate
in the example above.
We use to recommend adding extra dummy series to be shown in the legend.
You'd have one extra series for each entry you want to show in the legend. You can set their
Color
property to match the colors of the main series, setting your custom
Title
to them, but without adding any data to them.
Knowing their indexes, you could modify the code in the
to only activate
ShowInLegend
property for those dummy series.
X-ray
Post
by X-ray » Fri Apr 05, 2024 10:07 am
Ok, I just had to populate the Title properties of the Line Series, all perfect now, thanks!
- Latest2Capture.PNG (498.9 KiB) Viewed 62627 times
