Recompilation tool issue
dwpss
Post by dwpss » Wed Dec 14, 2022 6:08 pm
Fails on installation of Lazarus:
TeeChart Pro
Compilation started: 12/14/2022 12:53:22 PM
Lazarus 2.2.4.0
Cannot recompile Lazarus package: TeeChart.pas
Free Pascal Compiler version 3.2.2 [2022/09/24] for x86_64
Copyright (c) 1993-2021 by Florian Klaempfl and others
Target OS: Win64 for x64
Compiling C:\Delphi\TeeChart Pro VCL FMX Source Code\Source\TeeChart.pas
TeeChart.pas(85,40) Error: Duplicate identifier "TEEACTIVITYGAUGE"
TeeChart.pas(85,62) Error: Duplicate identifier "TEEACTIVITYGAUGEEDIT"
Compiling ArrowCha.pas
Compiling TeEngine.pas
Compiling TeeProcs.pas
Compiling TeCanvas.pas
TeCanvas.pas(790,18) Warning: An inherited method is hidden by "SetJoinStyle(const TPenJoinStyle);"
TeCanvas.pas(3164,1) Fatal: There were 2 errors compiling module, stopping
Fatal: Compilation aborted
Error: C:\lazarus\fpc\3.2.2\bin\x86_64-win64\ppcx64.exe returned an error exitcode
EXCEPTION:
Compilation aborted.
dwpss
Re: Recompilation tool issue
Post by Yeray » Wed Dec 14, 2022 6:58 pm
Yes, I found and fixed those errors yesterday.
I've just sent you the modified units at the mail you have registered in this forum.
Please let us know if there's any other problem with it.
dwpss
Post by dwpss » Thu Dec 15, 2022 4:31 am
Got past those errors, but it seems there is some pathing needed still...I have sent you the log output file since it is very long.
dwpss
Post by Yeray » Thu Dec 15, 2022 7:27 am
The log ends with:
Compiling C:\lazarus\components\ideintf\idewindowintf.pas
idewindowintf.pas(26,3) Fatal: Can't find unit IDEOptionsIntf used by IDEWindowIntf
I also saw that error and didn't find how to fix it yet.
In the meanwhile, I could open the teechart.lpk package and compile and install it from the IDE.
Could you please give it a try?
Sorry for the inconvenience generated.
dwpss
Post by dwpss » Thu Dec 15, 2022 3:00 pm
I can install it manually in the IDE but upon use I get this error when trying to use the TeeChart Editing dialog box...
Screenshot 2022-12-15 095624.png (22.56 KiB) Viewed 17801 times
dwpss
Post by Yeray » Fri Dec 16, 2022 7:46 am
I see the error in "Tree mode". We'll investigate what's wrong.
Meanwhile, please open the "options" and uncheck it.
dwpss
Post by dwpss » Fri Dec 16, 2022 2:53 pm
When doing so I can get a little further but upon choosing an item from the gallery it stops with...
Screenshot 2022-12-16 094742.png (91.47 KiB) Viewed 17749 times
Screenshot 2022-12-16 094311.png (19.27 KiB) Viewed 17749 times
dwpss
Post by Yeray » Mon Dec 19, 2022 7:33 am
At TeeGally.pas, find the TTeeGallery.SwitchAlternate procedure and modify this line:
      ChartListBox1.Sorted:=True;
For this:
      {$IFNDEF LCL}
      {$ENDIF}
And rebuild the package.
I'm sorry for the inconveniences.
Post by Yeray » Mon Dec 19, 2022 10:59 am
Hello again,
The above could be considered as a fast workaround.
I've just implemented the definitive fix (I hope so) for #2578.
The fix consists on adding a couple of lines of code at TTeeGallery.CreateChartList, in TeeGally.pas unit, setting Sorted:=False befode updating the ChartListBox1 and restoring it at the end:
Procedure TTeeGallery.CreateChartList(Const APage:String);
  ChartListBox1.Items.BeginUpdate;
  ChartListBox1.Sorted:=False;
  try
  finally
    ChartListBox1.Sorted:=AlternateStyle;
    ChartListBox1.Items.EndUpdate;
dwpss
Post by dwpss » Tue Dec 20, 2022 4:30 am
That got rid of the sort error, but things are odd.
If you choose something from the series gallery the associated code is not generated and if you do too much in the gallery it crashes.
Here are some screenshots...
Screenshot 2022-12-19 231759.png (30.32 KiB) Viewed 17523 times
The resultant code:
Screenshot 2022-12-19 231827.png (14.85 KiB) Viewed 17523 times
After making changes to a series from the gallery, like checking "smooth" etc.:
Screenshot 2022-12-19 230806.png (30.75 KiB) Viewed 17523 times
pssdw
dwpss
Post by dwpss » Mon Jan 02, 2023 8:56 pm
Also, I have tried to use without the Gallery with this test...
pssdw
uses
  Classes, SysUtils, Forms, Controls, ExtCtrls, Graphics, Dialogs, StdCtrls,
  TeEngine, Chart, TeeGDIPlus, Series, TeeProcs;
type
  { TForm1 }
  TForm1 = class(TForm)
    Chart1: TChart;
    Series1: TLineSeries;
    procedure FormShow(Sender: TObject);
  private
  public
var
  Form1: TForm1;
implementation
{$R *.lfm}
{ TForm1 }
  Series1.FillSampleValues(50);
Screenshot 2023-01-02 155516.png (8.42 KiB) Viewed 17344 times
