Pyramid / Sales Funnel
Markus46
Post by Markus46 » Wed Sep 28, 2022 12:53 am
Hello. I have a couple of questions regarding TPyramidSeries.
First off. I think there may be a bug with Tooltips when the LeftAxis is inverted.
Using your Pyramid_Series unit
Pyramid_Series.zip
My replacement Pyramid_Series unit for Tee9new. Illustrates ToolTip issue.
(2.09 KiB) Downloaded 676 times
Tee9new, I add a Mark Tips tool to the chart and set it like so:
  TMarksTipTool(Chart1.Tools[0]).Style := smsLabelValue;
With LeftAxis non-inverted, I see tooltips as expected. When inverted I do not see tooltips.
Finally, I expect this is possible but I am not experienced enough with TChart.
I add data to the series like so:
  Series1.Add(100, 'Design');
  Series1.Add(150, 'Programming');
  Series1.Add(90,  'Systems Test');
  Series1.Add(200, 'QA');
I would like to show the label on the LeftAxis, not values. So in the above case, there would be 4 ticks on the left axis being Design, Programming, Systems Test and QA.
How can this be done? I can provide a sample if necessary.
Mark
Re: Pyramid / Sales Funnel
Post by Yeray » Thu Oct 06, 2022 12:10 pm
Hello Mark,
I've been able to reproduce it so I've added it to the public tracker (#2561).
You could do something like this:
uses TeePyramid;
var i: Integer;
    sum: Double;
  Chart1.Color:=clWhite;
  Chart1.Walls.Hide;
  Chart1.Title.Hide;
  Chart1.View3D:=False;
  Chart1.Legend.Hide;
  Chart1.Hover.Hide;
  Chart1.Axes.Bottom.Labels:=False;
  with TPyramidSeries(Chart1.AddSeries(TPyramidSeries)) do
    Add(100, 'Design');
    Add(200, 'QA');
    sum:=0;
    for i:=0 to Count-1 do
      sum:=sum+YValue[i];
      Chart1.Axes.Left.Items.Add(sum, Labels[i]);
  Chart1.Axes.Left.Inverted:=True;
Markus46
Post by Markus46 » Thu Oct 13, 2022 5:50 am
Thanks so much for your response!
I'll try your suggestion re labels on left axis.
