TDonutSeries with DonutPercent
bdw
Post by bdw » Wed Feb 13, 2019 2:09 am
Just trying to work out an issue I'm getting with the TDonutSeries when using the DonutPercent value which used to display correctly on an older TChart version but getting an issue with v2018.26.181203.
Code example is :-
	TDonutSeries* d = new TDonutSeries(Chart1);
	d->Add(20);
	d->Add(10);
	d->Add(20);
	d->Add(25);
	d->Add(25);
	d->AngleSize = 180;
	d->Marks->Visible = false;
	d->DonutPercent = 60;
	Chart1->AddSeries(d);
	Chart1->View3D = false;
	Chart1->Legend->Visible = false;
	// add
	Chart1->Hover->Visible = false;
	Series1->Clear();
	Series1->Add(20);
	Series1->Add(10);
	Series1->Add(20);
	Series1->Add(25);
	Series1->Add(25);
	Series1->AngleSize = 180;
	Series1->Marks->Visible = false;
	Chart2->View3D = false;
	Chart2->Legend->Visible = false;
Which produces an image like this on the left with the items all crammed together rather than spread out around the donut ?
bdw
Re: TDonutSeries with DonutPercent
Post by bdw » Wed Feb 13, 2019 2:20 am
Actually just realized when I was playing around I had changed the Series1 to a TPieSeries.
When I change that back to a TDonutSeries it draws all together as well.
But question is the same, why is the dount not spread around the series ?
If I turn on 3D it displays correctly but not when 2D ?
bdw
Post by bdw » Wed Feb 13, 2019 2:22 am
Image example :-
bdw
Post by bdw » Wed Feb 13, 2019 3:17 am
Ok looks like its been a bug since v24 and been around for quite a while.
http://bugs.teechart.net/show_bug.cgi?id=2031
Same issue looks like work around is to make 3D and set the following :-
Chart1->Chart3DPercent = 0;
Chart1->Aspect->Elevation = 0;
bdw
Post by bdw » Wed Feb 13, 2019 4:34 am
In our actual application it does not draw correctly with those settings unless GDI+ is used.
I removed in our code :-
// graph_->Canvas = new TTeeCanvas3D;
I have not been able to replicate that in a test application though, so not sure why on this aspect.
We had been using GDI due to speed issue with background images but I'm guessing this may have been resolved at some point.
Post by Yeray » Wed Feb 13, 2019 3:43 pm
I did a modification to try to fix this problem:
viewtopic.php?f=3&t=16643
However, precisely today I found that fix broke the TDonutSeries drawing when using GDI and 2D.
The Donut function I modified assumes StartAngle and EndAngle are already in radians.
To fix v2018.27, please revert that Donut function in TeCanvas.pas removing the DegToRad call and leave it as it was before:
procedure TTeeCanvas3D.Donut( XCenter,YCenter,XRadius,YRadius:Integer;
                              Const StartAngle,EndAngle,HolePercent:Double);
  CalcPoint(StartAngle,x3,y3);
  CalcPoint(EndAngle,x4,y4);
Then, to fix the TPointSeries pointer you can modify the DrawPointer function at TeEngine.pas as follows:
Procedure TSeriesPointer.DrawPointer( const ACanvas:TCanvas3D;
                                      Is3D:Boolean;
                                      px,py,Horiz,Vert:Integer;
                                      ColorValue:TColor;
                                      AStyle:TSeriesPointerStyle);
        psDonut: if Is3D then
                    if ACanvas.View3DOptions.Orthogonal then
                      tmpP:=ACanvas.Calculate3DPosition(PX,PY,tmpZ);
                      Donut({$IFDEF FMX}Round{$ENDIF}(tmpP.X),{$IFDEF FMX}Round{$ENDIF}(tmpP.Y),Horiz,Vert,0,DegToRad(360),50);
                    end
                      EllipseWithZ(PXMinus,PYMinus,PXPlus,PYPlus,tmpZ)
                    Donut(PX,PY,Horiz,Vert,0,DegToRad(360),50);
This fix will be included in the next maintenance release.
bdw
Post by bdw » Mon Feb 18, 2019 9:10 pm
Only just had time to verify and yes that seems to have sorted it.
Much appreciated.
