Dave C.
Post
by Dave C. » Sat Jul 09, 2016 3:00 pm
I have both Delphi Seattle and Delphi Berlin installed. The source code recompile tool installs Seattle correctly, but fails on the Berlin install. The compile starts and then I am getting the following Exception:
Cannot open file "C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2016.18\Compiled\Delphi24.win32\System\Tee924.bpl". The system cannot find the file specified
I am selecting under RX10.1 Berlin "Win32 v24 (C++)".
How do I install the latest version with Berlin?
Dave
Post
by Yeray » Mon Jul 11, 2016 7:27 am
Hello Dave,
Do you Tee924.bpl in that folder?
Try running TeeRrecompile "as administrator" if you haven't.
Dave C.
Post
by Dave C. » Mon Jul 11, 2016 1:10 pm
No, the file Tee924.bpl does not exist in the folder.
I am running the TeeRecompile from the folder C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2016.18 as if I run it from the Programs menu, the default folders for source and destination are incorrect.
In the destination folder C:\Program Files (x86)\Steema Software\Steema TeeChart Pro VCL FMX Source Code 2016.18\Compiled\Delphi24.win32\System the only files that exists is GLUT32.dll.
Thanks for your help!
Dave
Post
by Yeray » Mon Jul 11, 2016 2:01 pm
Hi Dave,
Dave C. wrote:the default folders for source and destination are incorrect
Are you changing the source/destination folders?
This is how it looks for me by default:
- TeeRecompile_2016-07-11_15-59-43.png (46.27 KiB) Viewed 48657 times
If it gives you any compilation error, please open the Log tab to see if there is some extra detail about where does it come from.
Dave C.
Post
by Dave C. » Mon Jul 11, 2016 3:20 pm
Yes, those are the folders I have.
The log says:
TeeChart Pro
Compilation started: 7/11/16 11:08:36 AM
Win32 v24 (C++)
Tee924
This version of the product does not support command line compiling.
TeeUI924
TeeDB924
TeePro924
TeeGL924
TeeImage924
TeeWorld924
TeeLanguage924
TeeImport924
DclTee924
DclTeePro924
DclTeeProStd924
TeeMaker124
DclTeeMaker124
I do not have C++ installed, only Delphi.
Dave
Post
by Narcís » Mon Jul 11, 2016 3:29 pm
Hi Dave,
Thanks for the information. Given the error message you get, you are probably experiencing the problem Embarcadero describes
here:
Embarcadero wrote:Some customers have reported that the Delphi compiler (dcc32.exe) that they have in their installation having a correct Professional, Enterprise or Architect edition of the product is not the correct one. This compiler is used if you perform builds outside of the IDE (for instance during the installation of several 3rd party components).
The first step of the installation of the IDE using the new feature installer installs a basic IDE with very limited functionality. This mini-IDE has the “trial” Delphi compiler that cannot be used to compile any program (trial licenses don’t include the final command line compilers). Afterwards, once you install the 32-bit Windows platform, the real “dcc32.exe” has to be copied to the “bin” folder of the product. Under some circumstances (an antivirus accessing the “trial” dcc32.exe file, for instance) the compiler is not correctly overwritten and you could still have the “trial” version on your “bin” folder.
If you have this problem please copy the correct dcc32 compiler from:
C:\Users\Public\Documents\Embarcadero\Studio\18.0\CatalogRepository\Core_Common_Files_Enterprise-18.0.Build.22858.6822\TARGETDIR\bin
Or
C:\Users\Public\Documents\Embarcadero\Studio\18.0\CatalogRepository\Core_Common_Files_Professional-18.0.Build.22858.6822\TARGETDIR\bin
To the “bin” folder of your installation (by default C:\Program Files (x86)\Embarcadero\Studio\18.0\bin) and the issue will disappear.
Does this solve the problem at your end?
Dave C.
Post
by Dave C. » Mon Jul 11, 2016 4:09 pm
Thanks it! Thank you. I was unaware of this Embarcadero problem.
Dave
Post
by Narcís » Tue Jul 12, 2016 7:29 am
Hi Dave,
You're very welcome. I'm glad to hear that helped.
Dave C. wrote:I was unaware of this Embarcadero problem.
I was also unaware, just searched for the error message on the net.
