Question about RotateLabel
johnnix
Post by johnnix » Fri Oct 09, 2015 6:55 pm
I am using TChart 2015.15.150420 32 bit and I am using Canvas3D.RotateLabel to draw a rotated text. The last parameter of the RotateLabel procedure is AllowHTML which I set to true. What HTML should I use to present a subscript character?
Re: Question about RotateLabel
Post by Yeray » Tue Oct 13, 2015 3:24 pm
<SUB>SubScript Text Here</SUB>
johnnix
Post by johnnix » Tue Oct 13, 2015 4:23 pm
Hello Yeray,
I tried that but unfortunately it does not work, my actual code is:
procedure TMainForm.Chart11AfterDraw(Sender: TObject);
  TChart(Sender).Canvas.RotateLabel(X, Y, '<SUB>SubScript Text Here</SUB>', 45 , true);
Am I missing something?
Post by Narcís » Wed Oct 14, 2015 9:53 am
Hello johnnix,
It works for me compared with non-subscript text, for example:
var X, Y: Integer;
  TChart(Sender).Canvas.Font.Size:=15;
  X:=100;
  Y:=X;
  TChart(Sender).Canvas.RotateLabel(X, Y, 'Normal Text <SUB>SubScript Text Here</SUB>', 45 , true);
johnnix
Post by johnnix » Wed Oct 14, 2015 5:24 pm
Hello Narcis,
Could it be my version? I just tried a plot Title in HTML and that does not work also (double clicked a plot -> Titles -> Options -> Format HTML) :(
Post by Yeray » Thu Oct 15, 2015 7:59 am
I've just checked it works in v2015.15 for me here:
The position of the Subscript text isn't correct with oblique angles, but the text and the font size look correct.
Note I've added this to output the build version string on the chart title:
uses TeeConst;
  Chart1.Title.Text.Text:=TeeMsg_Version;
johnnix
Post by johnnix » Thu Oct 15, 2015 6:37 pm
... does not work for me :( What could be the issue?
Screenshot 2015-10-15 21.png (12.36 KiB) Viewed 36747 times
Post by Yeray » Fri Oct 16, 2015 11:47 am
What IDE are you using?
johnnix
Post by johnnix » Fri Oct 16, 2015 12:19 pm
Delphi XE7 Version 21.0.17707.5020
Post by Yeray » Fri Oct 16, 2015 3:33 pm
Looking again at your screenshot I've seen what is making the difference here: RotateLabel method doesn't support HTML5 tags in GDI Canvas.
http://bugs.teechart.net/show_bug.cgi?id=1343
In the meanwhile you can use GDIPlus instead of GDI.
johnnix
Post by johnnix » Sun Oct 18, 2015 7:43 am
Understood :)
Post by Yeray » Wed Feb 15, 2017 1:20 pm
Reviewing if it's worth implementing the support for the HTML in RotateLabel, doesn't GDIPlus satisfy your needs?
Post by Yeray » Wed Mar 01, 2017 8:40 am
#1343 has been closed as "Won't Fix". We recommend moving to GDIPlus.
