JES
Post
by JES » Wed Mar 12, 2014 7:24 am
in TeeChart Pro v2014.10.140220 (32bit VCL) GetChartGalleryFunction opens functions gallery empty (nothing in combo or listbox to select).
After open if you switch first Templates tab and then back to Functions tab then functions list is filled.
var MyFunc:TTeeFunctionClass;
MyFunc := GetChartGalleryFunction(Self);
Janne
JES
Post
by JES » Thu Mar 13, 2014 7:44 am
can you send me fixed file (I can recompile)?
Janne
Post
by Yeray » Thu Mar 13, 2014 4:06 pm
I've prepared a beta installer so you can check it.
I'll send the link to the mail account you have registered in this forum.
JES
Post
by JES » Tue Mar 18, 2014 7:43 am
this version does not open dialog at all.
(Even in chart editor if you try to change series type (Change button) it does not open anything).
Janne
Post
by Yeray » Tue Mar 18, 2014 3:52 pm
Hello Janne,
Find attached a simple example project. It opens the functions gallery when I click the button.
Doesn't it work for you?
JES
Post
by JES » Tue Mar 18, 2014 6:29 pm
no it does not.
- TeeGally.png (14.08 KiB) Viewed 9940 times
I have also DewReserch components which integrates yours component (I have recompiled all), so could this be problem.
(it does not add anything on functions list but in gallery list it does)
Has always worked fine before.
- DewResearch.png (20.28 KiB) Viewed 9947 times
Janne
Post
by Yeray » Wed Mar 19, 2014 3:41 pm
Hi Janne,
That's strange. What OS and IDE are you running?
JES wrote:I have also DewReserch components which integrates yours component (I have recompiled all), so could this be problem.
Have you tried unchecking DewReserch packages in the components list in the IDE to see if it makes the difference?
JES
Post
by JES » Mon Apr 07, 2014 5:54 am
sorry for late reply.
I tried to uncheck DewReserch (no difference).
Delphi Version is XE3 and OS is Win7 Pro
Now I had time to check this, and it seems that in this version in code active tab was left to Templates tab (TeeGally.pas) (and it is not visible when you call GetChartGalleryFunction, so that was reason of List index out of bounds (3).
Otherwise it is now working, thanks!
Janne
