TColorGrid Cursor Tracking
I have a chart with a TColorGridSeries. I'd like to be able to display x, y, z values on the screen as the mouse cursor moves about the chart. I've tried using the Mark Tips Tool, but got no results. I've also tried writing a handler for the MouseMove event of the chart. In the handler, I call Series->GetCursorValueIndex(), but it always returns -1. What is the best way to accomplish what I'm trying to do? I'm using TeeChart Pro 8.06.
Re: TColorGrid Cursor Tracking
Narcis,
Thanks for the reply. It appears that Clicked() is working the same as GetCursorValueIndex(). I still get -1 for a majority of the points on the grid. The grid contains about 230K points. I am getting values for points where the X value is less than 0.735. The points were added with the X value varying last (the outer loop). If it matters, please also note that I had to set IrregularGrid to true, because the X values are floats. They are regular, but separated by 0.105474 seconds. There are 1327 such time values, and the left axis consists of integer values from 10 to 186.
Hi skassan,
Can you please try with TeeChart Pro v8.08 VCL, which is the last v8 release? Does this work fine for you? Otherwise, can you please attach a simple example project we can run "as-is" to reproduce the problem here?
Narcis,
Before downloading a new version of the software, I wanted to be sure I could create a small project that reproduces the problem. It turns out that the problem happens when I turn the Pen off for the Grid.
Below is some code, and the form file to recreate the problem. As shown below, the code exhibits the exact problem I see. But by simply removing the line in the form file that says: Pen.Visible = False, the problem goes away.
Unit1.cpp
Unit1.dfm:
Unit1.cpp
#include <vcl.h>
#pragma hdrstop
#include "Unit1.h"
#pragma package(smart_init)
#pragma link "Chart"
#pragma link "TeEngine"
#pragma link "TeeProcs"
#pragma link "TeeSurfa"
#pragma resource "*.dfm"
TForm1 *Form1;
__fastcall TForm1::TForm1(TComponent* Owner)
: TForm(Owner)
for (int i = 0; i < 1327; ++i)
for (int j = 10; j < 187; ++j)
Series1->AddXYZ(0.105474 * i, Random(), j);
void __fastcall TForm1::Chart1MouseMove(TObject *Sender, TShiftState Shift, int X,
int Y)
Label1->Caption = Series1->Clicked(X, Y);
object Form1: TForm1
Left = 0
Top = 0
Caption = 'Form1'
ClientHeight = 286
ClientWidth = 426
Color = clBtnFace
Font.Charset = DEFAULT_CHARSET
Font.Color = clWindowText
Font.Height = -11
Font.Name = 'Tahoma'
Font.Style = []
OldCreateOrder = False
PixelsPerInch = 96
TextHeight = 13
object Label1: TLabel
Left = 128
Top = 264
Width = 31
Height = 13
Caption = 'Label1'
end
object Chart1: TChart
Left = 0
Top = 0
Width = 418
Height = 250
Title.Text.Strings = (
'TChart')
View3D = False
TabOrder = 0
OnMouseMove = Chart1MouseMove
ColorPaletteIndex = 8
object Series1: TColorGridSeries
Marks.Arrow.Visible = True
Marks.Callout.Brush.Color = clBlack
Marks.Callout.Arrow.Visible = True
Marks.Callout.Length = 0
Marks.Visible = False
EndColor = clBlue
IrregularGrid = True
MidColor = clYellow
Pen.Visible = False
StartColor = clRed
XValues.Name = 'X'
XValues.Order = loNone
YValues.Name = 'Y'
YValues.Order = loNone
ZValues.Name = 'Z'
ZValues.Order = loNone
end
end
end
Hi skassan,
I'm having problems assembling the sample project. Would you mind attaching the complete project?
Narcis,
I've uploaded a zip file with all of the project files.
In the mean time, I've been experimenting with the problem. Since it seemed to be related to the Pen.Visible property, I set that to True, and changed the PenStyle to psClear. That helped. But I ran into the same problem when I had to change the IrregularGrid property to True. I need to do this because sometimes my data interval along the X-axis is larger than one. In the attached example, the interval is 63.488. In that case, if IrregularGrid is False, the graph is not contiguous. It only shows bars one unit wide every 63.488 units. But when I set IrregularGrid to True, the problem with Clicked() not working correctly reappears.
Thanks for all of your help.
Hi skassan,
Where did you send the files? Did you press the "Add the file" button after browsing for attachments?
Yes, I did. And I watched in Task Manager as the Network Activity for outgoing messages increased, and then went idle again. Then the screen refreshed, wiping out my reply. So I typed it in again, and hit submit.
Trying again...
Trying again...
Hi skassan,
No luck yet. Can you see the file attached here? Please be aware that you didn't get any error message. The forums board doesn't allow certain file types and displays an error message. Alternatively you can send your files at http://www.steema.net/upload/.
Ok. Using the web link, I got a file size too big error. I included the Debug folder in the zip file. I'll remove that and try again.
- Unit1.zip
- (6.43 KiB) Downloaded 1494 times
Hi skassan,
Thanks for the example project. I couldn't get it working here either toggling IrregularGrid or Pen visibility. I could reproduce the problem using code snippet below to so I have added this issue (TV52015637) to the defect list to be investigated for future releases.
uses TeeSurfa;
var Series1: TColorGridSeries;
x, z : Integer;
Series1:=TColorGridSeries.Create(Self);
Series1.IrregularGrid:=True;
Chart1.AddSeries(Series1);
for x:=0 to 101 do
for z:=0 to 2139 do
Series1.AddXYZ(63.488 * x, Random, z);
procedure TForm1.Chart1MouseMove(Sender: TObject; Shift: TShiftState; X,
Y: Integer);
Caption:=IntToStr(Chart1[0].Clicked(X,Y));
Is there public access to your bug tracking tool? Will I be notified when a fix is available?
Hi skassan,
No but asking for this ticket number we can inform you about its status anytime.
We don't use to do that. When a new release is published it comes with what we call the release notes. This is a list with the bug fixes and new features included in the release. I recommend you to be aware at this forum, our RSS news feed, twitter and facebook accounts for new release announcements and what's implemented on them.Will I be notified when a fix is available?
