Painting non-rectanglar point with Anti-Aliasing tool
Michael Heinrich
Post by Michael Heinrich » Fri Feb 19, 2010 10:16 am
Version: Build 8.06.60902
Hereby I send a project that contains a chart with three series. The chart has an Anti-Aliasing tool attached and is active.
When you change the pointer type to anything other than rectangular shape (any non-horizontal line/non-vertical line in the pointer, example Circle or triangle) the IDE crashes.
Steps to reproduce:
Open the form in IDE
Right click on chart and select the option for series.
Select any series and alter the pointer style into a circle.
The IDE crashes.
procedure TAntiAliasCanvas.LineTo(X, Y: Integer);
      if ISolid then
          while (xs<x) and (xs<[b]Bitmap[/b].Width) do
            yt:=yt+k;
            tmpYt:=Floor(yt);
I have traced the error and discovered that the application crashes on procedure TAntiAliasCanvas.LineTo(X, Y: Integer); line 988. When trying to determine the width of the bitmap it turns out that the bitmap is nil.
This crashes my entire IDE and I have to restart the IDE. Also at runtime this error occurs when you show the dialog to change the chart properies via the TeeCommander.
Project23.zip
Form with AntiAlias Tool, LineSeries, PointSeries all have rectangle pointers
(9.27 KiB) Downloaded 1571 times
Re: Painting non-rectanglar point with Anti-Aliasing tool
Post by Yeray » Fri Feb 19, 2010 4:53 pm
Hi Michael,
I've been able to reproduce it so I've added it to the defect list to be fixed asap (TV52014692)
Post by Yeray » Thu Feb 25, 2010 3:17 pm
Hi Michael,
I'd like you to know that the bug (TV52014692) has been fixed so it should work fine in the next maintenance v8 release.
Post by Narcís » Thu Feb 25, 2010 3:29 pm
Hi Michael,
In the meantime you can solve that checking if Bitmap is not nil, for example:
        if ISolid then
          if Assigned(Bitmap) then
            while (xs<x) and (xs<Bitmap.Width) do
              yt:=yt+k;
              tmpYt:=Floor(yt);
              if tmpYt < 0 then tmpYt:=0;
              if tmpYt > Bitmap.Height then tmpYt:=Bitmap.Height-2;
              dist:=yt-tmpYt;
              oneDist:=1-dist;
              BlendColor1(xs, tmpYt);
              BlendColor2(xs, tmpYt+1);
              Inc(xs);
        end
