Sorting and Grouping data in Lazarus
Nintegra
Post by Nintegra » Wed Sep 29, 2021 12:46 pm
Is it possible to sort and group data in TeeGrid in Lazarus? I have data with several thousand rows and a couple of dozen columns and I need to sort and group it by clicking the header.
I tried to use different data providers, for example:
- RTTI. Can't compile. Seems not supported in Lazarus.
- DB. The sorting and grouping functions are not supported by default.
- Strings. It is an array of arrays of strings. Also does not support sorting and grouping by default.
So maybe I'm missing something. Could you show examples of these functions in Lazarus?
Re: Sorting and Grouping data in Lazarus
Post by Marc » Wed Oct 06, 2021 10:34 am
We're looking at options. TeeGrid Sort depends on the availability of RTTI. We'll get back with any suggestions we may be able to make.
Nintegra
Post by Nintegra » Mon Nov 08, 2021 9:43 am
Ok, i am using TBufSet and Indexes to sort data. But i can't find the way to simple concatenate columns.
For example i need just a header in two columns. But when i try to do this, the data is always empty.
(demo -> Lazarus -> Database -> ClientDataSet)
In the default stringgrid, I can concatenate columns by drawing rectangles above the cells. Is there something like this in teegrid?
Post by Yeray » Thu Nov 11, 2021 2:55 pm
I'm not sure to understand the situation. You seem to be adding two sub-columns under "TITLE", but then you want to concatenate them?
Nintegra
Post by Nintegra » Fri Nov 12, 2021 2:10 pm
Yes, that's right, I added two columns. But, I cannot put the data inside.
For example, i want to move the "title" data inside the "qwe" column, and the "author" data inside the "asd" column.
scrn 2021-11-12 170918.png (10.22 KiB) Viewed 45162 times
This project is from the official demo.
tee_grid_demo_project.zip
(160.72 KiB) Downloaded 2040 times
Post by Yeray » Fri Nov 19, 2021 2:15 pm
I'm afraid the only way to do this would be using a different structure as explained here.
