Series redraw with color grid
vishwa
Post by vishwa » Wed Aug 01, 2018 5:35 am
We are using Chart color grid with 400 series and each series having 1000 points. And we have two separate charts one is vertical and one is horizontal. so that, based on cursor position of main chart which is having 400 series, we are drawing vertical chart and horizontal chart separately. The main chart is having nulls both side first 100 points and last 100 points. My concern is till the cursor position is on values means without nulls it is redrawing the chart correctly, but once if it goes null area and coming back to values area it is not redrawing the chart. can any one let me know what will be the cause and how i can resolve it. If require more info i can provide.
Sravan
Re: Series redraw with color grid
Post by Sandra » Wed Aug 08, 2018 12:30 pm
Hello vishwa,
Could you attached us a simple project because we can reproduce the problem you're experiencing here and we can give you a solution for that?
Thanks in advance
vishwa
Post by vishwa » Thu Aug 09, 2018 4:02 am
Hi Sandra,
Thanks for your reply. I got solution for that.
Thanks & Regards,
Sravan
