TeeChart Animation
Re: TeeChart Animation
Thanks. Just what I needed to see.
I have since moved to Tokyo, update 3 and purchased the Pro version. But every time I try to add to change things in the Chart Editor, Delphi seems to crash with the attached error.
After downloading AnimationsChart.zip and automated the Pie Chart using the timer method. I'm a bit surprised that the animation requires it's own timer. But I am having a problem automating the 4 series Bar Chart. Since I can't mess with the editor, what I would like is a bit of example code.
I want to be able to animate all the bars at once after ALL of their queries are executed. Just like the zip file, but with all series if active.
- 2018-04-07_0950.png (7.19 KiB) Viewed 28666 times
I've cleaned the project a little bit and added several bar series to it. See how it moves in this gif:
1. Can you tell me what controls the spacing between the bars? As you can see from this image, the bars kinda overlap. I would like them to be evenly spaced and not overlapping.
2. After I drill down to a small pie slice, the bar char is hardly noticeable. How do I adjust the chart so the Bar height is recognizable? In other words, how do I lower the grid to match the bar size so when I drill down, it will fill the bar chart.
3. How can I tell which bars are checked?
- 2018-04-09_0838.png (37.81 KiB) Viewed 28651 times
- 2018-04-09_0837.png (73.42 KiB) Viewed 28653 times
http://bugs.teechart.net/show_bug.cgi?id=2027
Sounds as a rounding issue. I've added it to the public tracker:realsol wrote:1. Can you tell me what controls the spacing between the bars? As you can see from this image, the bars kinda overlap. I would like them to be evenly spaced and not overlapping.
How are you doing that drill down? Could you please arrange a simple example project we can run as-is to reproduce the problem here?realsol wrote:2. After I drill down to a small pie slice, the bar char is hardly noticeable. How do I adjust the chart so the Bar height is recognizable? In other words, how do I lower the grid to match the bar size so when I drill down, it will fill the bar chart.
You can loop all the series and see which ones are "TBarSeries" and "Active". Ie:realsol wrote:3. How can I tell which bars are checked?
var i: Integer;
if (Chart1[i] is TBarSeries) and (Chart1[i].Active) then
//do whatever
You may be interested in the Pro Support option.realsol wrote:- Bump -
This was the same as the regular rectangle bars as all my other images in my other posts show. There are so many setting (a tribute to a mature component offering), I know I was the one that caused it. I don't know how.Sounds like a rounding issue. I've added it to the public tracker:
I can demonstrate with two graphics.How are you doing that drill down? Could you please arrange a simple example project we can run as-is to reproduce the problem here?
1. This first one shows a bar graph representing all income and expense category totals by month.
2. The second chart represents the result after a user clicks on the shopping category slice
I would like to redraw the grid to match the highest bar like on the first chart. For the user, it is hard to tell the shopping totals which such $7000 grid.
- After user clicks on the 'Shopping' slice
- 2018-04-11_0903.png (48.76 KiB) Viewed 28599 times
- All Bars and full pie
- 2018-04-11_0902.png (32.67 KiB) Viewed 28598 times
The exact place and exact values depend on the exact code in your project, but you probably have to call SetMinMax(min, max) on the Left axis to set the axis scale that better fits the data to show.
Thanks. I'll give it a shot. My Bar Chart has 4 series each controlled by a Query.
If I display the chart with animation (with queries that lower the values of the bars), the bars are updated, but the OnGetLegendText never gets called, so the amounts and text remain the same. Here is the code:
If I comment out the above code, both the bars and legend are updated when the queries are updated. How can I update the legend to the correct values when using animation?
if DBChart2.Tools.Count = 1 then
with DBChart2.Tools.Add(TSeriesAnimationTool) as TSeriesAnimationTool do
duration := 250;
Series:=DBChart2[4];
Play;
I'm trying to reproduce the problem with this code but it seems to work fine for me here:
If you still find problems, please arrange a simple example project we can run as-is the problem here.
uses Series, TeeAnimations;
var animationTool: TSeriesAnimationTool;
Chart1.View3D:=False;
ColorEachPoint:=True;
Marks.Hide;
FillSampleValues;
animationTool:=Chart1.Tools.Add(TSeriesAnimationTool) as TSeriesAnimationTool;
with animationTool do
Duration:=250;
Series:=Chart1[0];
Play;
var i: Integer;
for i:=0 to Chart1[0].Count-1 do
Chart1[0].YValue[i]:=Chart1[0].YValue[i] - 10;
animationTool.Play;
