iOS compilation error
X-Ray
Post by X-Ray » Tue Jun 19, 2012 11:47 am
I just downloaded and Installed the latest TChart version (TeeChart 2012.06.120613 VCL/FMX release).
Then I copied the content of the FMI folder to the fmi folder on my MAC, overwritting the previous TChart sources (which were working).
After that I tried to compile my prohject again and I get the following compilation errors (starting just before the first error):
FMX_ListBox.pas(1468,3) Note: Local variable "Allow" not used
FMX_ListBox.pas(244,5) Note: Private field "TCustomComboBox.FPlacement" is never used
Assembling (pipe) /Users/thomasdegen/Library/Developer/Xcode/DerivedData/iHighScore-grimquailgfpngeacooqsyxudquv/Build/Products/Release-iphonesimulator/iHighScore.app/FMX_ListBox.s
FMXTee_Canvas.pas(626,21) Error: Identifier not found "TAlphaColor"
FMXTee_Canvas.pas(626,21) Error: Error in type definition
FMXTee_Canvas.pas(656,30) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(658,43) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(670,29) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(670,29) Error: This kind of property can't be published
FMXTee_Canvas.pas(670,66) Error: Property can't have a default value
FMXTee_Canvas.pas(670,78) Error: Identifier not found "TAlphaColors"
FMXTee_Canvas.pas(682,30) Error: Illegal expression
FMXTee_Canvas.pas(805,23) Error: This kind of property can't be published
FMXTee_Canvas.pas(805,43) Error: Property can't have a default value
FMXTee_Canvas.pas(805,55) Error: Identifier not found "TAlphaColors"
FMXTee_Canvas.pas(813,23) Error: This kind of property can't be published
FMXTee_Canvas.pas(813,43) Error: Property can't have a default value
FMXTee_Canvas.pas(822,23) Error: This kind of property can't be published
FMXTee_Canvas.pas(822,43) Error: Property can't have a default value
FMXTee_Canvas.pas(822,55) Error: Identifier not found "TAlphaColors"
FMXTee_Canvas.pas(830,21) Error: Illegal expression
FMXTee_Canvas.pas(836,49) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(869,34) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(869,34) Error: This kind of property can't be published
FMXTee_Canvas.pas(869,77) Error: Property can't have a default value
FMXTee_Canvas.pas(870,40) Error: Identifier not found "clDefault"
FMXTee_Canvas.pas(870,40) Error: The default value of a property must be constant
FMXTee_Canvas.pas(1008,24) Error: Illegal expression
FMXTee_Canvas.pas(1035,39) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1050,25) Error: Illegal expression
FMXTee_Canvas.pas(1055,60) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1071,30) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1071,30) Error: This kind of property can't be published
FMXTee_Canvas.pas(1104,22) Error: Illegal expression
FMXTee_Canvas.pas(1105,22) Error: Illegal expression
FMXTee_Canvas.pas(1108,22) Error: Illegal expression
FMXTee_Canvas.pas(1122,35) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1139,54) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1139,74) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1141,42) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1143,42) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1146,44) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1156,24) Error: Illegal expression
FMXTee_Canvas.pas(1157,24) Error: Illegal expression
FMXTee_Canvas.pas(1158,24) Error: Illegal expression
FMXTee_Canvas.pas(1185,33) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1186,33) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1189,35) Error: Type "TColor" is not completely defined
FMXTee_Canvas.pas(1202,25) Error: This kind of property can't be published
FMXTee_Canvas.pas(1203,25) Error: This kind of property can't be published
FMXTee_Canvas.pas(1206,27) Error: This kind of property can't be published
FMXTee_Canvas.pas(1217,25) Error: This kind of property can't be published
FMXTee_Canvas.pas(1218,25) Error: This kind of property can't be published
FMXTee_Canvas.pas(1218,25) Fatal: There were 50 errors compiling module, stopping
So the first compilation error is: FMXTee_Canvas.pas(626,21) Error: Identifier not found "TAlphaColor"
Did nobody test this before the release or do I miss something?
What should I do to get this compiled?
best regards,
X-Ray
Re: iOS compilation error
Post by Sandra » Fri Jun 22, 2012 9:20 am
Hello X-Ray,
Ok. You are right. We find in top of page of TeCanvas.pas(FMXTee_Canvas.pas) there is an error that breaks the code and do it doesn't complie when you use FreePascal in Mac + FMI:
{$IFDEF D17}
     System.UIConsts,
     {$ENDIF}
Lines need change to next:
     {$IFDEF D16}
     System.UIConsts,
     {$ENDIF}
We will fix it to upcoming maintenace release of TeeChartVCL.
X-Ray
Post by X-Ray » Mon Jun 25, 2012 7:02 am
Hello Sandra,
I just changed the sources in unit "FMXTee_Canvas.pas", starting at line number 81 from:
{$IFDEF D17}
{System.}UIConsts,
{$ENDIF}
to
{$IFDEF D16}
{System.}UIConsts,
{$ENDIF}
But I still get the same compilation errors.
How to get this compiled, are there more changes?
best regards,
X-Ray
Post by Sandra » Mon Jun 25, 2012 11:20 am
Hello X-Ray,
Thanks for information. We are investigating to find a solution for this problem and we will try to fix it asap.
X-Ray
Post by X-Ray » Mon Jul 02, 2012 1:24 pm
Hello Sandra,
do you have any news concerning a working/compiling version for iOS?
best regards,
X-Ray
Post by Sandra » Thu Jul 05, 2012 7:55 am
Hello X-Ray,
Sorry for the delay. We have made for you, an installer, where the problem is fixed. I have sent you an email with information.
rlebbar
Post by rlebbar » Mon Jul 23, 2012 5:05 pm
Hi Sandra
I just updated delphi xe2 (4) to (4H1)
and Installed for the first time the latest version of TeeChart Pro.
Project that used to work do not work any more with the same error as above.
Please how can i get this installer where the problem is fixed ?
it is urgent ! Thanks.
Best regards
rlebbar
Post by Yeray » Thu Jul 26, 2012 12:18 pm
Hi rlebbar,
I've just sent it to the mail account you have registered in this forum.
