Is it possible to show a dynamic chart with fixed bar align and size?
I'd like to show my chart with vertical bars with width 5 and all them to right align.
On the follow attached example I built it using rectangles, so I just created the object in runtime and put it on the right side, I'd say my rectangle chart 'moves' from right to left.
I'd like to do something like that using TeeChart
I'm using TeeChart Pro 2020 + RadStudo 10.4.1 + FMX.
Chart with non automatic bar aling/size
- Untitled.jpg (24.87 KiB) Viewed 36093 times
Re: Chart with non automatic bar aling/size
I've fixed it following this tip: https://stackoverflow.com/questions/661 ... 4#66136734
I'm glad to hear you found a solution.
An alternative would be to play with
CustomBarWidth
or with the bottom axis scale SetMinMax(min, max)
.Best Regards,
