Changing the value color on linear gauge
mts
Post by mts » Thu Jun 07, 2012 2:56 pm
I'm trying to change the color of the value bar on the linear gauge. Can't get it to work. I've tried:
linearGaugeSeries = new LinearGauge(chart1.getChart());
linearGaugeSeries.getValueAreaBrush().setColor(Color.RED);
linearGaugeSeries.getValueAreaBrush().setForegroundColor(Color.RED);
linearGaugeSeries.getFaceBrush().setColor(Color.RED);
linearGaugeSeries.getFaceBrush().setForegroundColor(Color.RED);
but it always stays blue like this screenshot. This is with the v2012 evaluation version.
linear gauge color.png (14.45 KiB) Viewed 18612 times
mts
Re: Changing the value color on linear gauge
Post by mts » Thu Jun 07, 2012 3:13 pm
Also having a probelm setting the increment on a regular Gauges series.
double dHigh = 8000;
double dLow = 0;
gaugeSeries = new Gauges(chart1.getChart());
gaugeSeries.setMinimum(dLow);
gaugeSeries.setMaximum(dHigh);
gaugeSeries.getHorizAxis().setIncrement((dHigh - dLow)/10);
gaugeSeries.getVertAxis().setIncrement((dHigh - dLow)/10);
chart1.getAxes().getLeft().setIncrement((dHigh - dLow)/10);
chart1.getAxes().getBottom().setIncrement((dHigh - dLow)/10);
gauges no increment.png (13.64 KiB) Viewed 18583 times
Post by Yeray » Mon Jun 11, 2012 1:57 pm
Hi Mark,
mts wrote:I'm trying to change the color of the value bar on the linear gauge. Can't get it to work.
Try with:
linearGaugeSeries.getHand().setColor(Color.RED);
mts wrote:Also having a probelm setting the increment on a regular Gauges series.
You are right. It seems the Gauges axis increment is forced to 10. I've fixed it for the next maintenance release so this will work fine:
WhebJava
Post by WhebJava » Wed May 29, 2013 9:05 pm
About mts problem, I have the same problem.
Do you have a date to release this fix?
Post by Yeray » Thu May 30, 2013 2:52 pm
WhebJava wrote:About mts problem, I have the same problem.
I see two problems here:
One with a workaround suggested:
Try with:
And a second one that should be fixed with v3.2013.0517:
Which one of the problems are you reproducing? And what TeeChart version are you using?
