Question about rendering chart under apache server
landa
Post by landa » Wed Oct 22, 2008 6:02 pm
The Javascript under the apache server seems to get stuck at some of the charting code. I'm using teechart 5 active x.
This code gets rendered:
function onloadtchartIncidentsByDepartment() {
TChartComtchartIncidentsByDepartment.Chart = tchartIncidentsByDepartment;
tchartIncidentsByDepartment.Header.Font.Bold = true;
tchartIncidentsByDepartment.Header.Font.Name = "Arial";
tchartIncidentsByDepartment.Header.Font.Size = 14;
tchartIncidentsByDepartment.Header.Text.Clear();
tchartIncidentsByDepartment.Header.Text.Add("Incidents By Department");
This code below does not get rendered, I get a Javascript error.
"Object Expected"
The code is all in the same function:
tchartIncidentsByDepartment.Series(0).VerticalAxis = aLeftAxis;
tchartIncidentsByDepartment.Series(0).Add (3, "10K", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (1, "5JO", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (1, "5PA", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (1, "5SI", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (2, "ACC", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (23, "ADMIN", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (2, "ADMIT", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (1, "GES", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (3, "QM", 536870912 );
tchartIncidentsByDepartment.Series(0).Add (1, "WCOMP", 536870912 );
Any ideas or help would be greatly appreciated.
Post by Narcís » Fri Oct 24, 2008 3:33 pm
Hi landa,
We have been checking references to Apache and ActiveX, though our initial thought is that this issue relates to clientside script only. Please could you send us your page at news://www.steema.net/steema.public.attachments newsgroup or at our upload page?
landa
Post by landa » Mon Oct 27, 2008 6:18 pm
Hi Narcis,
I've uploaded the files last week. Have you found anything wrong or missing yet in the pages?
Post by Marc » Tue Oct 28, 2008 12:50 pm
Of the scriptfiles you sent, common_procs_tchart.tcl contains script to write to the browser an outputted page that includes a TeeChart object and script.
The script is similar though not exactly the same as the script with which you've reported the problem below. For us to view that script, understanding now that Apache may only be being used in this context to generate the web pages (not to process TeeChart), it may be easier if you do a right-mouseclick on the page in question to view source and to send us a copy of that page 'as is' in html.
Otherwise, something you could check beforehand, if your script is running correctly and only failing at the line in question:
..then that seems to be the first reference to a data Series. Please check that your code does actually add a Series to the Chart, otherwise that will report an 'object not found' error.
