Pictures on Gantt Charts
JD
Post by JD » Fri Sep 19, 2008 2:28 pm
In our project we have a gantt chart. Each Bar is standing for another Person with a special job. Now we need to add to the bars picture, every picture will stand for the persons job and the picture should be visible in the first quarter of a bar.
Is there a simple solution to reach this?
greetings
JD
Post by Pep » Mon Sep 22, 2008 8:45 am
there's not a way to it automatically through methods and properties, but it can be accomplished by drawing directly onto the canvas using the Draw method. Here I show an example which draws an image into the first gantt bar :
' This will add image for first gant....
TChart1.Canvas.Draw TChart1.Axis.Bottom.CalcXPosValue(TChart1.Series(0).XValues.Value(0)), _
                    TChart1.Axis.Left.CalcYPosValue(TChart1.Series(0).YValues.Value(0)) - _
                    TChart1.Series(0).asGantt.Pointer.VerticalSize / 2, _
                    Image1.Picture
JD
Post by JD » Mon Sep 29, 2008 1:50 pm
Works Great.
But now I have the problem that the images are also on the non charted area and I dont know how to use the ClipRectangle Function. Can you give just an example?
Post by Narcís » Mon Sep 29, 2008 1:53 pm
Hi JD,
You'll find an example of ClipRectangle's usage here.
Hope this helps!
JD
Post by JD » Mon Sep 29, 2008 2:39 pm
Now it's working. But next Problem how can I make the Images on the Gantt transperance?
Post by Pep » Mon Oct 06, 2008 7:39 am
I'm afraid this is not going to be possible, as the Draw method does not include transparency support. We'll add on our wish list to be considered for further releases.
