Date labels on line series chart
Roger Nye
Post by Roger Nye » Sun Aug 17, 2008 7:51 pm
I am trying to set up a line series with dates on the bottom axis.
Unfortunately, I am having to do this in Java using the ActiveX version through OLE codes, so it can be difficult to work out what is going on.
If there is a candle series in the chart it gives dates, but for a chart with only line series it gives value labels, I thought I could do the following:
1. Get the IAxes OLE automation object through ITChart.Axis (code 2)
2. Get the IAxisLabels automation through IAxis.Labels ( code 11)
3. Set the DateTimeFormat property using IAxisLabels.DateTimeFormat (code 6) to "dd/mm/yy"
It accepts the property change and returns 0, but the axis values still appear as values. (e.g. 39,215).
Any suggestions
Many thanks
Roger
Post by Yeray » Mon Aug 18, 2008 10:21 am
Hi Roger,
Have you set the XValues as DateTime? For Candle series it is set by default, but not for line series.
To force it you should do the following:
TChart1.Series(0).XValues.DateTime = true
Roger Nye
Post by Roger Nye » Mon Aug 18, 2008 10:46 am
Thanks Yeray,
That worked.
Roger
