SImple Question - No answer
MCD
Post by MCD » Fri Nov 16, 2007 4:02 pm
I create new series using ASP script: Chart.AddSeries(4) How can I make the size of the points smaller than the default block? I want like a 4 pixel size dot or atleast somewhat smaller than the defaut size.. Running TeeChart Active x ver 6
Documentation is very very hard to follow of course I could be just an idiot but here is what I have so far I have two series and I simply want to make the points smaller:
Chart.AddSeries(1)
Chart.AddSeries(4)
Chart.Series(0).Marks.Visible=False
Chart.Series(0).Color=vbYellow
Chart.Series(0).VerticalAxis=1
Chart.Series(0).Name="Level"
Chart.Series(0).XValues.DateTime = True
Chart.Series(1).Marks.Visible=False
Chart.Series(1).Color=vbBlue
Chart.Series(1).Name="Parameter"
Thanks!!
Post by Narcís » Fri Nov 16, 2007 4:56 pm
Hi MCD,
Yes, you can do this:
    TChart1.Series(0).asPoint.Pointer.VerticalSize = 4
    TChart1.Series(0).asPoint.Pointer.HorizontalSize = 4
MCD
Post by MCD » Fri Nov 16, 2007 5:40 pm
THanks that worked.. can you show me where I can find where this example is in the documentation? I have been searching and reading for nearly 3 hours with no help... I only do ASP code so the other examples look like Greek to me.
Jason
Post by Yeray » Mon Nov 19, 2007 8:49 am
There is a demo called "Reducing Number of Points" where is used this and there is the "Pointer" demo where does something similar for a Point Series. (Use search option to fins the demos).
Also you can take a look at the help file and look for IPointer property.
