Can change IAnnotationTool.Callout arrow color in code?
ellab_user
Post by ellab_user » Fri Feb 23, 2007 9:27 am
I have an annotation with a callout arrow and can change the color of it in the editor via Callout->Pointer->Pattern->Color, but can't see where to do this in code. We use ActiveX 6.
Post by Yeray » Fri Feb 23, 2007 10:11 am
Hi ellab_user,
You should do something like following:
TChart1.Tools.Items(0).asAnnotation.Callout.Brush.color = vbRed
ellab_user
Post by ellab_user » Fri Feb 23, 2007 10:55 am
We are using TeeChart ActiveX 6 in C#, and I don't get .Brush after Callout. Why?
Post by Narcís » Fri Feb 23, 2007 11:24 am
Hi ellab_user,
Works fine here using the code below with TeeChart Pro v6.0.0.6 in Visual Studio 2005. Does this work fine at your end? Which TeeChart version are you using?
axTChart1.Tools.get_Items(0).asAnnotation.Callout.Brush.Color = axTChart1.Series(0).Color;
ellab_user
Post by ellab_user » Fri Feb 23, 2007 12:02 pm
Doesn't complíle...."'TeeChart.IAnnotationCallout' does not contain a definition for 'Brush'".
We have Version 6.0.0.4
Post by Narcís » Fri Feb 23, 2007 12:09 pm
Hi ellab_user,
Could you please uninstall v6.0.0.4, download the latest version available at the client area, install it and check if it works fine at your end?
If the problem persists please send us a simple example project we can run "as-is" to reproduce the problem here. You can either post your files at news://www.steema.net/steema.public.attachments newsgroup or at our upload page.
ellab_user
Post by ellab_user » Fri Feb 23, 2007 12:46 pm
Yes - 6.0.0.6 works - Thanks!
p.s.-Is the newest version 6.0.0.7 or 6.0.1.1?
Post by Narcís » Fri Feb 23, 2007 12:56 pm
Hi ellab_user,
I'm glad to hear that.
v6.0.0.6 is the latest full version installer but v6.0.1.1 is the latest maintenance update release.
