Drawing Polygon on Canvas in OnAfterDraw
LAL
Post by LAL » Sat Sep 12, 2020 3:50 am
In C++ ActiveX v8, I want to draw a direction arrow on my line series that points along the line.
I've calculated the points of the arrow (below) - but I'm not sure how to put them into the VARIANT for the Polygon?
Is it supposed to be an array of CPoints? Or an integer list of coordinates?
void MyDialog::OnAfterDraw()
	int nValues = m_Chart.Series(1).GetXValues().GetCount();
	int nHalf = nValues / 2;
	CPoint to(m_Chart.Series(0).CalcXPos(nHalf ), m_Chart.Series(0).CalcYPos(nHalf));
	CPoint from(m_Chart.Series(0).CalcXPos(nHalf - 1), m_Chart.Series(0).CalcYPos(nHalf - 1));
	int x1 = to.x;
	int y1 = to.y;
	int x2 = from.x;
	int y2 = from.y;
	CPoint p1, p2, p3;
	int xres = 8;		// Size of arrow
	double theta;
	double theta2 = atan(0.5);
	double hypot = sqrt(double(xres * xres) * 5/4);
	double l;
	p1 = CPoint(0, 0);
	p2 = CPoint(0, 0);
	p3 = CPoint(0, 0);
	// Calculate angle of line
	if (y2 == y1)
		theta = ((x2 > x1) ? 0.0 : PI);
		theta = atan((double) (y2 - y1) / (double) (x2 - x1));
		if ((y2 > y1) && (x2 < x1))
			theta = PI + theta;
		if ((y1 > y2) && (x1 > x2))
			theta = PI + theta;
	// If arrow is in the middle, adjust P1 to line centre
	if (TRUE)
		l = 0.6 * hypot * cos(theta2);
		p1.x = long(x2 + l * cos(theta) + 0.5);
		p1.y = long(y2 + l * sin(theta) + 0.5);
		p1.x = x2;
		p1.y = y2;
	p2.x = long((p1.x - hypot * cos (theta + theta2)) + 0.5);
	p2.y = long((p1.y - hypot * sin (theta + theta2)) + 0.5);
	p3.x = long((p1.x - hypot * cos (theta - theta2)) + 0.5);
	p3.y = long((p1.y - hypot * sin (theta - theta2)) + 0.5);
	m_Chart.GetCanvas().GetPen().SetColor(RGB(0, 0, 0));
	m_Chart.GetCanvas().GetPen().SetWidth(1);
	m_Chart.GetCanvas().GetBrush().SetColor(RGB(0, 0, 255));
	m_Chart.GetCanvas().GetBrush().SetBackColor(RGB(0, 0, 255));
	VARIANT pts; // <<<<<<------- How to construct this?
	m_Chart.GetCanvas().Polygon(3, pts);
Kyudos
Re: Drawing Polygon on Canvas in OnAfterDraw
Post by Kyudos » Sat Sep 12, 2020 9:28 am
After some trial and error I found this seems to work...is it correct?
	VARIANT pts;
	VariantInit(&pts);
	pts.vt = VT_ARRAY|VT_I4;
	SAFEARRAY* psa = SafeArrayCreateVector(VT_I4, 0, 6);
	if (psa != NULL)
		LONG i;
		i = 0; SafeArrayPutElement(psa, &i, &p1.x);
		i = 1; SafeArrayPutElement(psa, &i, &p1.y);
		i = 2; SafeArrayPutElement(psa, &i, &p2.x);
		i = 3; SafeArrayPutElement(psa, &i, &p2.y);
		i = 4; SafeArrayPutElement(psa, &i, &p3.x);
		i = 5; SafeArrayPutElement(psa, &i, &p3.y);
	pts.parray = psa;
	SafeArrayDestroy(psa);
Post by Yeray » Mon Sep 14, 2020 1:14 pm
In the AddArrays example here, we populate arrays in a similar way than what you are doing. So it looks good to me.
- .h:
class CVCTeeChart5Dlg : public CDialog
public:
  COleSafeArray XValues;
  COleSafeArray YValues;
- .cpp:
BOOL CVCTeeChart5Dlg::OnInitDialog()
  DWORD numElements[] = {200000};
  // Create the safe-arrays...
  XValues.Create(VT_R8, 1, numElements);
  YValues.Create(VT_R8, 1, numElements);
  // Initialize them with values...
  long index;
  for(index=0; index<200000; index++) {
      double val = index+((rand()*5)/RAND_MAX);
      XValues.PutElement(&index, &val);
  srand(100);
      double val = index+rand();
      YValues.PutElement(&index, &val);
