teechart
ugur
teechart
Post by ugur » Fri Mar 17, 2017 2:53 pm
hello
i use TeeChart2016_0_0_2_ActiveX3264
after install..
in a form..
in after add teechart control, edit control, i need help. press F1. i not found "\teechartx2016.hlp"
where is it?
-sorry for poor english-
Re: teechart
Post by Yeray » Fri Mar 17, 2017 4:00 pm
ugur
Re: teechart
Post by ugur » Sat Mar 18, 2017 8:40 am
thank you for reply Yeray.
i use TeeChart2016_0_0_2_ActiveX3264 or TeeChart2017_0_0_0_ActiveX3264
but i could not found any example of chart animation (VB).
Not present in the sample code.
How or where can I find an example?
Are you guiding me?
Re: teechart
Post by Yeray » Mon Mar 20, 2017 10:20 am
It seems to be a bug. I've added it to the public tracker:
http://bugs.teechart.net/show_bug.cgi?id=1821
ugur
Re: teechart
Post by ugur » Tue Mar 21, 2017 8:37 am
hello, thanks for reply.
This problem is also present in TeeChart2017_0_0_0_ActiveX3264.exe to TeeChart2014_0_0_3_ActiveX3264.exe.
I've tried.
But I saw this feature in an application and it worked fine.
I learned that this application is using v8.
I want to use or try this feature.
But I think my license is available between TeeChart2017_0_0_0_0_0_ActiveX3264.exe and TeeChart2014_0_0_3_ActiveX3264.exe.
Is there a place I can download v8?
Can I use v8 with my current license?
thank you.
Ugur.
Re: teechart
Post by Yeray » Tue Mar 21, 2017 9:58 am
I've just found it seems to be broken since v2014.0.0.0.
You can find the previous version, v2013.0.1.4 at the "Release archive" tab in the Client Area.
ugur
Re: teechart
Post by ugur » Tue Mar 21, 2017 3:17 pm
OK.
I'm trying that version.
But there is a license problem.
Is this normal?
thank you.
Re: teechart
Post by Yeray » Wed Mar 22, 2017 7:11 am
ugur wrote:But there is a license problem.
What's the problem?
ugur
Re: teechart
Post by ugur » Wed Mar 22, 2017 9:18 am
after uninstall TeeChart2017_0_0_0_ActiveX3264
install TeeChart2013_0_1_4ActiveX3264 with required license information (internet direct connected and no problem)
about window
Unregistered
teechart pro v2013.0.1.4.131120 32bit activex
Re: teechart
Post by Yeray » Wed Mar 22, 2017 2:22 pm
Sounds similar to this:
http://www.teechart.net/support/viewtop ... 51&p=71814
As you can read there, note this doesn't limit your product in any manner.
ugur
Re: teechart
Post by ugur » Wed Mar 22, 2017 5:20 pm
Thank you again for your reply.
Does the situation I'm talking about create a problem?
The answer is very important to me.
Because a program I write will be a very critical task.
Re: teechart
Post by Yeray » Thu Mar 23, 2017 8:35 am
ugur wrote:Does the situation I'm talking about create a problem?
Having "Unregistered" in the about box? There's no problem with that, as it doesn't limit the component.
