Setting Number of Horizontal Grid Lines While Zooming
tirby
Post by tirby » Wed Aug 07, 2013 9:04 pm
The graph is setup to follow the 1-2-5 rule across 20 horizontal lines for the Y-Axis of the grid during normal view.
My customer is requesting that the number of horizontal grid lines remain constant (20 Lines) while in Zoomimg or Panning.
How can I do this?
Re: Setting Number of Horizontal Grid Lines While Zooming
Post by Yeray » Thu Aug 08, 2013 3:26 pm
What about setting a Left Axis Increment each time the chart is zoomed/unzoomed?
Ie:
Dim nGridLines As Integer
Private Sub Form_Load()
  TChart1.Aspect.View3D = False
  TChart1.AddSeries scLine
  With TChart1.Series(0)
    .FillSampleValues
  End With
  nGridLines = 20
  recalcIncrement
Private Sub TChart1_OnUndoZoom()
  recalcIncrement
Private Sub TChart1_OnZoom()
  recalcIncrement
Private Sub recalcIncrement()
  With TChart1.Axis.Left
    .Increment = (.Maximum - .Minimum) / nGridLines
  End With
tirby
Post by tirby » Fri Aug 09, 2013 8:34 pm
Yeray,
Thanks for the info.
That got me started in the right direction.
I also had to set the min.Separation % to 0 to keep the 20 lines from disappearing if the graph height is set to short.
I modified the code to cover both left and right axis.
