OnClickSeries not detecting up candles correctly
Bower
Post by Bower » Fri Dec 12, 2003 1:03 pm
In a chart displaying a candle series, I think there is something wrong with the hit testing for "up" candles. It seems that these are only detected if the mouse is directly over the candle centre line but not anywhere else in the candle body. The hit testing seems to work correctly for "down" candles though.
The problem affects, OnClickSeries, OnMouseEnterSeries events and also the ISeries>>GetMousePointer() method.
I'm using TeeChart v6 and I've also set a custom candle width via ICandleSeries>>CandleWidth() if that makes any difference. Is there, perhaps, a workaround for this problem or will I need to wait for a future bug fix to become available.
Thanks in advance
Post by Marc » Mon Dec 15, 2003 6:53 am
Thanks for letting us know. This seems to be a problem and has been logged to be fixed.
With regards to workarounds, if the Candle is set as 1 pixel width Bar not Stick the hit rate is 100% (and hence a clue to where the internal problem lies).
A 'long' workaround (this works) would be to check clicks against a calculation made of each Candle Rectangle. Steps would include sending the X,Y click to a routine that steps through visible Series points
Eg.
Private Sub TChart1_OnMouseDown(ByVal Button As TeeChart.EMouseButton, ByVal Shift As TeeChart.EShiftState, ByVal x As Long, ByVal y As Long)
  vIdx = CheckCandlePoint(x, y)
  TChart1.Repaint
Private Function CheckCandlePoint(ByVal x As Integer, ByVal y As Integer) As Integer
  Dim openValY, closeValY
  With TChart1
    i = -1
    For i = .Series(0).FirstValueIndex To .Series(0).LastValueIndex
      openValY = .Series(0).CalcYPosValue(.Series(0).asCandle.OpenValues.Value(i))
      closeValY = .Series(0).CalcYPosValue(.Series(0).asCandle.CloseValues.Value(i))
      If openValY < closeValY Then
        topY = openValY
        bottomY = closeValY
      Else
        topY = closeValY
        bottomY = openValY
      End If
      If x > .Series(0).CalcXPos(i) - (.Series(0).asCandle.CandleWidth / 2) And _
         x < .Series(0).CalcXPos(i) + (.Series(0).asCandle.CandleWidth / 2) And _
         y > topY And y < bottomY Then
        CheckCandlePoint = i
      End If
    Next i
  End With
End Function
If you prefer to make the click sensitive to the entire area between high and low values instead of the open and close rectangle then simply replace in highValues and lowValues for the Open and CloseValues in the calculation above.
