LoadFromFile : ShowInEditor Property not loaded
guilz2010
Post by guilz2010 » Thu Dec 16, 2010 5:14 pm
New issue with LoadFromFile/SaveToFile function : when property .ShowInEditor of a serie is set to True at the SaveFromFile phase (for example in MACD function where by default only serie0 and serie1 are displayed in Editor, not serie2 and serie3) this property is not loaded on the LoadFromFile phase for serie2 and serie3.
Could you confirm this issue and add it to our 'to solve wishes list' :D
Guilz
    Private Sub ButtonSave_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ButtonSave.Click
        AxTChart1.RemoveAllSeries()
        AxTChart1.Aspect.View3D = False
        AxTChart1.Axis.Left.EndPosition = 49
        AxTChart1.AddSeries(TeeChart.ESeriesClass.scCandle)
        AxTChart1.Series(0).FillSampleValues(100)
        AxTChart1.Series(0).Title = "Source Random Serie"
        AxTChart1.Axis.AddCustom(False)
        AxTChart1.Axis.Custom(0).StartPosition = 51
        AxTChart1.Axis.Custom(0).EndPosition = 100
        AxTChart1.AddSeries(TeeChart.ESeriesClass.scLine)
        AxTChart1.Series(1).SetFunction(TeeChart.EFunctionType.tfMACD)
        AxTChart1.Series(1).DataSource = AxTChart1.Series(0)
        AxTChart1.Series(1).FunctionType.Period = 10
        AxTChart1.Series(1).VerticalAxisCustom = 0
        AxTChart1.Series(1).Title = "MACD1"
        AxTChart1.Series(2).VerticalAxisCustom = 0
        AxTChart1.Series(2).Title = "MACD2"
        AxTChart1.Series(2).ShowInEditor = True
        AxTChart1.Series(3).VerticalAxisCustom = 0
        AxTChart1.Series(3).Title = "MACD3"
        AxTChart1.Series(3).ShowInEditor = True
        AxTChart1.Export.asNative.SaveToFile("C:\test1.tee", True)
    Private Sub ButtonLoad_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ButtonLoad.Click
        AxTChart1.Import.LoadFromFile("C:\test1.tee")
    Private Sub ButtonClear_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles ButtonClear.Click
    Private Sub AxTChart1_OnAfterDraw(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles AxTChart1.OnAfterDraw
    Private Sub AxTChart1_OnDblClick(ByVal sender As Object, ByVal e As System.EventArgs) Handles AxTChart1.OnDblClick
        AxTeeEditor1.ChartLink = AxTChart1.ChartLink
        AxTeeEditor1.ShowEditor()
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Debug.Print("Title0:" & AxTChart1.Series(0).Title)
        Debug.Print("Title1:" & AxTChart1.Series(1).Title)
        Debug.Print("Title2:" & AxTChart1.Series(2).Title)
        Debug.Print("Title3:" & AxTChart1.Series(3).Title)
Re: LoadFromFile : ShowInEditor Property not loaded
Post by Yeray » Fri Dec 17, 2010 4:46 pm
Hi Guilz,
This will probably for the same reason than this: The internal series aren't exported.
I've added to the wish list the possibility to export also these internal series and their characteristics so they can be loaded later (TV52015326).
guilz2010
Post by guilz2010 » Mon Dec 20, 2010 7:50 am
Thank you Yeray
