Different series name and legend entries.
Hello all,
I have a situation where I want to call a series one thing (for example, <data item>, <source file>, <axis>), but want something else to appear in the legend (eg, <data item> or some additional text relating to the data).
Is this possible at the moment? I can only seem to set the legend entry to be a certain format, but the text always shows the series title.
Many thanks in advance,
Tony.
Tony.
Re: Different series name and legend entries.
Hi Tony,
You could use OnGetLegendText to personalize legend's text:
Private Sub Form_Load()
TeeCommander1.Chart = TChart1
Dim i As Integer
For i = 0 To 5
TChart1.AddSeries scPoint
TChart1.Series(i).FillSampleValues 5
Next i
Private Sub TChart1_OnGetLegendText(ByVal LegendStyle As Long, ByVal ValueIndex As Long, LegendText As String)
Select Case ValueIndex
Case 0: LegendText = "My first item"
Case 1: LegendText = "My second item"
Case 2: LegendText = "My third item"
Case 3: LegendText = "My fourth item"
Case 4: LegendText = "My fifth item"
Case 5: LegendText = "My sixth item"
End Select
Thanks for this, I can definitely work with that.
Would it be possible in a future release to allow the editing the legend text in a TChart commander window/dialog?
Tony.
Tony.
Hi Tony,
Yes, we already have in the wish list the possibility to fully customize all the items (number of items, text and legend symbol) to be included in future releases.
Is this in version 8.0.0.7? I notice the CLegendItems and CLegend classes, but how would you set the legend entry when adding a series (that is the ideal time to set the legend entry)?Yeray wrote:Hi Tony,
Many thanks,
Tony.
Hi Tony,
Right now you can't manually modify the number of items on the legend. The number of items in the legend will be:
- The number of series in the chart when legendstyle is lsSeries or lsLastValues.
- The number of values in the first series when legendstyle is lsValues.
- The number of groups when legendstyle is lsSeriesGroups.
What you can change is the text of each item that is going to be displayed with OnGetLegendText as said above.
Note that with TeeChart Pro v9 VCL there will be a CustomLegendTool that will allow to customize many other things.
That seems like the correct thing to me (and I have no need to change it).Yeray wrote: Right now you can't manually modify the number of items on the legend. The number of items in the legend will be:
All I want to do is create a series, give it a title, and set the legend entry for it at the same time. At the moment I need to create the series, store the legend entries, wait for the graph to draw, and then intercept "OnGetLegendText" to set the legend entries from the previous stored entries. If my users add their own plots, I lose the ability to do this as I have lost the ordering of the displayed series.
A function called "series.SetLegendText" is what I really need.
Does that make sense?
Tony.
Hi Tony,
Hmmm... I'm not sure to see the sense of it. In vcl (delphi) it is possible to do:
But I can't see the final difference of using the OnGetLegendText to do (ActiveX, VB6):
Could you please explain the exact steps to reproduce the problem? Maybe an simple example project we can run as-is here and/or some pictures would help us to understand what you have and what would you like to have.
Chart1.Legend.Item[0].Text:='custom text';
Case 0: LegendText = "custom text"
End Select
I'll try and explain.
First, I add some plots to the graph in my code (the format is "variable", "scenario", "axis")
time, scenario 1, LHS
population[US], scenario 1, LHS
population[UK], scenario 1, LHS
And I want to set the legend entries to
Simulation Time for scenario 1, LH Axis
US Population for default scenario
UK population for default scenario
At this point, I can use OnLegendGetText to set the legend entries as I know all of those plots are "mine", and what index they are in the tchart.
Now the user adds their own plot at runtime which is the sum of the two populations. I have no control over what they call the plot. The list of series now looks like this
total population (user generated)
I can now only use OnLegendGetText for the first series. As it is, the user generated plot would have the label entry "US Population for default scenario".
Does that make sense? All would be OK if I could set the legend entry for each series rather than use OnLegendGetText.
Tony.
Tony.
Hi Tony,
Couldn't you series' titles to be shown in the legend and use OnAddSeries to set a title for the series that the user will create?
Private Sub Command1_Click()
TChart1.AddSeries scLine
Dim i As Integer
For i = 0 To 1
Next i
TChart1.Series(0).Title = "US Population for default scenario"
TChart1.Series(1).Title = "UK Population for default scenario"
Private Sub TChart1_OnAddSeries(ByVal SeriesIndex As Long)
If SeriesIndex = 2 Then
TChart1.Series(SeriesIndex).Title = "total population"
TChart1.Series(SeriesIndex).FillSampleValues 5
End If
I would still lose track of which of the plots are "mine" that way (the "population[US], scenario 1, LHS" which identifies the plot as mine is lost).
Hi Tony,
Please try to arrange a simple example project we can run as-is to reproduce the problem here and we will see if we can find a solution for you.
There is a demo project attached to this message (it's very simple).
1. Run the project.
2. Click "Add first batch". Everything is operating normally.
3. Click "Editor". Add a new series, select "Functions" and "Add".
4. New series is now called "Series5".
5. Click "Add 2nd batch".
The legend entries are now not correct.
The only way around this at the moment is to keep a completely separate list of series legend entries, and also monitor OnSeriesAdd. All would be so much easier if you could just call something like "TChart1.Series(0).SetLegendEntry("some value")"
Tony.
1. Run the project.
Tony.
- TChartLegendDemo.zip
- (1.84 KiB) Downloaded 1057 times
Hi Tony,
If I understand well, you want to check if a series was added through the editor or by code at OnGetLegendText. If so, you could use an array to save the index of the series added by code. Take a look at the modifications I made to your code:
Option Explicit
Dim MySeries() As Integer
Dim NumEls As Integer
Dim i As Integer
NumEls = 0
For i = 0 To 4
TChart1.Series(i).FillSampleValues 10
Next i
TChart1.Series(0).Title = "Population[US], default, LHS"
TChart1.Series(1).Title = "Population[DE], default, LHS"
TChart1.Series(2).Title = "Population[IE], default, LHS"
TChart1.Series(3).Title = "Population[UK], default, LHS"
TChart1.Series(4).Title = "Population[FR], default, LHS"
Private Sub Command2_Click()
TChart1.ShowEditor
'TeeEditor1.ShowEditor
Private Sub Command3_Click()
Dim i As Integer
For i = 0 To 1
TChart1.Series(TChart1.SeriesCount - 1).FillSampleValues 10
Next i
TChart1.Series(TChart1.SeriesCount - 2).Title = "Population[IT], default, LHS"
TChart1.Series(TChart1.SeriesCount - 1).Title = "Population[ES], default, LHS"
Private Sub Command4_Click()
TChart1.Series(0).RefreshSeries
ReDim Preserve MySeries(NumEls + 1) As Integer
MySeries(NumEls) = SeriesIndex
NumEls = NumEls + 1
Dim i, MyIndex, UserCount As Integer
UserCount = -1
MyIndex = -1
For i = 0 To NumEls - 1
If MySeries(i) = ValueIndex Then
MyIndex = i
Else
If MySeries(i) > ValueIndex Then
UserCount = i
Exit For
End If
End If
Next i
If MyIndex <> -1 Then
Select Case MyIndex
Case 0:
LegendText = "US Population for default scenario"
Case 1:
LegendText = "DE Population for default scenario"
Case 2:
LegendText = "IE Population for default scenario"
Case 3:
LegendText = "UK Population for default scenario"
Case 4:
LegendText = "FR Population for default scenario"
Case 5:
LegendText = "IT Population for default scenario"
Case 6:
LegendText = "ES Population for default scenario"
End Select
Else
If UserCount = -1 Then
UserCount = NumEls
End If
LegendText = "user's series nº " + Str$(ValueIndex - UserCount)
End If
No. Ideally, I don't want to even use OnLegendGetText.Yeray wrote: If I understand well, you want to check if a series was added through the editor or by code at OnGetLegendText. If so, you could use an array to save the index of the series added by code. Take a look at the modifications I made to your code:
All I want to do is set the legend entry at the time I create the series. This workaround needs more work as well as I would need to capture if someone re-orders the series (try moving the top series down after adding the user series). All would be solved if there was a function to set the legend entry for a series instead of using OnGetLegendText.
Don't spend any time adding additional code to the demo above. I won't be implementing it, I'll work out some other way of doing what I need to do.
