Teechart2011.cab and evaluation version
Matheo Soft.
Post by Matheo Soft. » Fri Nov 18, 2011 9:47 am
Dear Support,
I test actually the ActiveX in order to buy a license (we are already client with Teechart VCL) but
I have a problem with the file Teechart2011.cab, I read of course the Section 18 without succes.
If i edit the teechart2011.ini file in the cab file, I see:
; INF file for TeeChart2011.ocx
[version]
; version signature (same for both NT and Win95) do not remove
signature="$CHICAGO$"
AdvancedINF=2.0
[Add.Code]
teechart2011.ocx=teechart2011.ocx
TeeUserx2011.hlp=TeeUserx2011.hlp
; needed hlpfile
[TeeUserx2011.hlp]
file-win32-x86=thiscab
DestDir=11
RegisterServer=yes
[teechart2011.ocx]
clsid={FCB4B50A-E3F1-4174-BD18-54C3B3287258}
FileVersion=9,0,0,0
RegisterServer=yes
; end of INF file
but in the cab file I have TeeChart2011Eval.ocx
Is for this reason that my I.E. can't show my chart ?
(of course, Eval version has been installed on a server, and in local (localhost), I.E. shows me a beautilful chart)
I read also in the "What more in.." file that you provides a link to a cab file ( http://www.steema.com/files/activex/pub ... chart9.cab
) but this link is broken. Do you have another one ? and could you tell me the version ?
Could you help me please?
Sincerely,
Bruno
Re: Teechart2011.cab and evaluation version
Post by Yeray » Tue Nov 29, 2011 10:52 am
Hi Matheo,
Matheo Soft. wrote:I have a problem with the file Teechart2011.cab, I read of course the Section 18 without succes.
    [version]
    AdvancedINF=2.0
    [Add.Code]
    ; needed hlpfile
    [TeeUserx2011.hlp]
    DestDir=11
    RegisterServer=yes
    [teechart2011.ocx]
    FileVersion=9,0,0,0
    RegisterServer=yes
    ; end of INF file
There was a problem in the cab generated. It should be corrected in next evaluation versions. In the meanwhile, here you can find the correct one:
http://www.steema.com/files/activex/pub ... 11Eval.cab
Matheo Soft. wrote:I read also in the "What more in.." file that you provides a link to a cab file ( http://www.steema.com/files/activex/pub ... chart9.cab
The correct file is at:
http://www.steema.com/files/activex/pub ... rt2010.cab
Could you please tell us where did you exactly find the wrong link so we can correct it?
Matheo Soft.
Post by Matheo Soft. » Tue Nov 29, 2011 11:08 am
Hi !
Damned it don't work even....
It works fine with http://127.0.0.1.... but if I try to connect from the "Net" the chart don't appear.... :'(
    <script language="VBScript">
    SUB FillChart
     With Chart1
         'sets up Chart to print from IE's print option
         .Environment.IEPrintWithPage=True
         .RemoveAllSeries
         .AddSeries(1)
         .Aspect.gdiplus.active = True
         .Aspect.View3D=False
     	 .Legend.Visible=False
         .Panel.Gradient.Visible=False
         .Panel.Color=RGB(255, 255, 255)
    	 .Walls.Visible = False
     End With
     With Chart1.Header
         .Text.Clear
         .Text.Add("Publication Date")
         .Transparent = True
     End with
     With Chart1.Footer.Font
         .Name = "Tahoma"
         .Bold = False
     End With
     With Chart1.Series(0)
         .Clear
         .Title="MyPatent"
         .ColorEachPoint=True
         .Add 47, "1998", 536870912
.Add 41, "2000", 536870912
.Add 20, "1990", 536870912
.Add 3, "1989", 536870912
.Add 36, "1992", 536870912
.Add 30, "2001", 536870912
.Add 50, "1994", 536870912
.Add 33, "1997", 536870912
.Add 49, "1999", 536870912
.Add 39, "1996", 536870912
.Add 37, "1991", 536870912
.Add 44, "1995", 536870912
.Add 32, "1993", 536870912
		 .Marks.Transparent = True
         .Marks.Style = smsValue
   	     .asBar.BarStyle = 8
		 .asBar.BarPen.Visible = false
		 .asBar.Transparency = 35
         .asBar.Shadow.Visible = False
         .asBar.Emboss.Visible = True
         .asBar.Emboss.VertSize = 3
         .asBar.Emboss.HorizSize = -4
         .asBar.Emboss.color = RGB(192, 192, 192)
         .Cursor = 2020
     End With
    END SUB
    Sub Chart1_OnClickSeries(SeriesIndex, ValueIndex, Button, Shift, X, Y)
        Chart1.StopMouse
	    if Chart1.Series(SeriesIndex).PointLabel(ValueIndex) <> "" then
          msgbox Chart1.Series(SeriesIndex).PointLabel(ValueIndex)
          msgbox Chart1.Series(SeriesIndex).YValues.Value(ValueIndex)
        end if
    end sub
	Sub Window_Onload()
		FillChart
   </script>
            <object
               id="Chart1"
               width="400"
               height="320"
               type="application/x-oleobject"
               hspace="0"
               vspace="0"
               classid="CLSID:FCB4B50A-E3F1-4174-BD18-54C3B3287258"
               codebase="http://XX.XXX.X.152:20080/tchart/Teechart2011Eval.cab#Version=9,0,0,0">
            </object>
Matheo Soft.
Post by Matheo Soft. » Tue Nov 29, 2011 11:11 am
Concerning the link, it was inside the file "What more in full version.txt" in the ActiveXEval version
Post by Narcís » Mon Dec 05, 2011 10:45 am
We have modified the demo, which I attach, and works fine for us here. Can you please check if it works fine at your end?
teechart2011cab - Copy.zip
(1.54 KiB) Downloaded 1095 times
Matheo Soft.
Post by Matheo Soft. » Mon Dec 05, 2011 10:59 am
Is it normal that you post a HTML file zipped ?
Otherwise, I downloaded the cab in this html file but It don't work, ... :'(
Pep
Post by Pep » Mon Dec 05, 2011 11:09 am
Hi Matheo,
you only have to unzip the file attached, and them run the html file by using internet explorer. It should try to use the cab file which has been uploaded on our web site, at a public place.
I'm able to run the file and allowing to run ocx file into the browser, see the chart component.
What happens when you do this ? what are you seeing into the browser ? which error does it give you ?
Matheo Soft.
Post by Matheo Soft. » Mon Dec 05, 2011 11:23 am
Hi Pep,
Ok your html file works fine, so now I will see the difference between your sample and mine.
Thx a lot !
Pep
Post by Pep » Mon Dec 05, 2011 11:31 am
Ok, I'm glad to hear it works now.
Matheo Soft.
Post by Matheo Soft. » Mon Dec 05, 2011 11:40 am
May be a network protection cause my problem...
Post by Sandra » Tue Dec 06, 2011 1:19 pm
Hello Matheo Soft,
Thanks for your information :). This information can help us and other clients to solve the similar problems as it.
