Legend shows wrong colors for Surface Series
yvb
Post by yvb » Tue Feb 15, 2011 1:03 pm
I am using TeeChart pro V8.0.0.6 Version v Active x, C++.
I am trying to use 3D Surface Series with my own pallets. as described in the code bellow.
The problem is that the surface colors are correct in the plot, but the legend shows the correct values(1,11,21,31) as defined in the calls to AddPalette(...) but he colors are different that the ones in the calls to AddPalette(...). It seems to be that the legend is using another palette for the chart.
1. Why do I get the wrong colors?
2. Is there a full example of using SurfaceSeries in C++ Active X?
Thanks;
YVB
	m_Chart.Series(m_lSeriesId).GetAsSurface().ClearPalette();
	m_Chart.Series(m_lSeriesId).GetAsSurface().AddPalette(1, RGB(0, 00, 0));
	m_Chart.Series(m_lSeriesId).GetAsSurface().AddPalette(11, RGB(255, 0, 0));
	m_Chart.Series(m_lSeriesId).GetAsSurface().AddPalette(21, RGB(0, 255, 0));
	m_Chart.Series(m_lSeriesId).GetAsSurface().AddPalette(31, RGB(0, 0, 255));
	m_Chart.Series(m_lSeriesId).GetAsSurface().AddXYZ(1, 0, 2,"",m_Chart.Series(m_lSeriesId).GetAsSurface().GetSurfacePaletteColor(0));
	m_Chart.Series(m_lSeriesId).GetAsSurface().AddXYZ(2, 10, 3,"",m_Chart.Series(m_lSeriesId).GetAsSurface().GetSurfacePaletteColor(10));
	m_Chart.Series(m_lSeriesId).GetAsSurface().AddXYZ(3, 20, 4,"",m_Chart.Series(m_lSeriesId).GetAsSurface().GetSurfacePaletteColor(20));
	m_Chart.Series(m_lSeriesId).GetAsSurface().AddXYZ(4, 30, 5,"",m_Chart.Series(m_lSeriesId).GetAsSurface().GetSurfacePaletteColor(30));
	m_Chart.Series(m_lSeriesId).GetAsSurface().SetUsePalette(true);
	m_Chart.GetLegend().GetSymbol().SetSquared(true);
	m_Chart.Repaint();
Re: Legend shows wrong colors for Surface Series
Post by Sandra » Thu Feb 17, 2011 12:16 pm
Hello
I recommend you update your TeeChart ActiveX version 8 for last Build that you can find in page download. When you have update your version, please try again if your problem persist and if it still appears please try to send us a simple project we can run as-is to reproduce the problem here so we can help you find a good solution.
yvb
Post by yvb » Wed Feb 23, 2011 7:48 am
Hi Sandra,
I prepared a project using TeeChart pro v8.0.0.8. The problem was not solved.
How do I send the project to you? I don't see any possibility for an attachemnt here.
yvb
Post by Narcís » Wed Feb 23, 2011 8:00 am
Hi yvb,
Yes, this forums board allows attachments at the bottom of the messages you'll see an "upload attachment option. Otherwise you can post them at our upload page.
yvb
Post by yvb » Wed Feb 23, 2011 2:51 pm
Attached is the file containing the solution in VS 2008 of my code.
I switched to TeeCahrt pro v8.0.0.8. But it didn’t help.
When executing to application click the “Test 3D Compact” button from the dialogue window.
The code using TChart is in CTchartDisplay::test3D_Compact() and CTchartDisplay::OnAfterDrawTchart1().
I am trying to do two things:
1. Display a 2D color Grid where each cell color represents a value in a specific range.
2. Draw a rotated ellipse over the grid.
I tried to implement thus by using Surface series, where the coordinate system was rotated by 270 degrees
Around the X axis, so the chart is viewed as 2D XZ coordinate system from the Y axis direction. The value Y for each XZ grid
point is displayed at a corresponding color that I defined in a color palette.
My problems/questions are:
1. The legend does not show the correct colors, but it shows the correct value ranges. How can I fix it?
2. How do I draw a rotated ellipse on the grid that is on the XZ plane? The RotatedEllipse() function draws the ellipse on the XY plane ( or parallel to it) so only it’s projection is seen on the grid as a red line.
3. How can I get the value of a Z coordinate in pixels, similar to CalcXPosValue(…) ?. This may enable me to draw shapes in the XZ plane.
4. Will the usage of ColorGrid Series instead of Surface Series simplify things and solve some of the problems?
yvb
StabilizationTeeChartForSteema.zip
(353.95 KiB) Downloaded 986 times
Post by Sandra » Mon Feb 28, 2011 1:20 pm
Hello yvb,
I recommend you use property ColorRange, and change it to false as do in below lines of code:
	m_Chart.Series(0).GetAsSurface().SetUseColorRange(false);
Yes, if you use ColorGrid, the problems that you have when you draw ellipse disappears. I have made a simple code for your using a ColorGrid Series instead of Surface Series and works fine for me here. Please, check if next code works as you want:
InitializeChart:
void CTchartDisplay::test3D_Compact()
	m_Chart.GetAspect().SetView3D(false);
	m_Chart.AddSeries(scColorGrid);
	m_Chart.Series(0).FillSampleValues(13);
	m_Chart.Series(0).GetPen().SetColor(RGB(0,255,255));
	m_Chart.GetEnvironment().InternalRepaint();
	m_Chart.GetCanvas().GetPen().SetColor(RGB(255,0,0));
	m_Chart.GetCanvas().GetPen().SetWidth(2);
AfterDraw Event:
void CTchartDisplay::OnAfterDrawTchart1()
	long x1 = m_Chart.GetAxis().GetTop().CalcXPosValue(4.0);
	long y1 = m_Chart.GetAxis().GetLeft().CalcYPosValue(5.0);
	long x2 = m_Chart.GetAxis().GetBottom().CalcXPosValue(6.0);
	long y2 = m_Chart.GetAxis().GetRight().CalcYPosValue(7.0);
	m_Chart.GetCanvas().RotatedEllipse(y1,x1,y2,x2,100, 0);
I hope will helps.
yvb
Post by yvb » Thu Mar 03, 2011 7:08 am
Thanks Sandra, everything works now in my application.
Best regards,
yvb
Post by Sandra » Thu Mar 03, 2011 9:22 am
Hello yvb,
I am glad that your problems are solved :).
