Labels in between points in line chart
I need to get two things in my Line graph. Attached is a sample to show what I am looking for.
1. Is it possible to have label in between the points? In my eg:- lables like "AAA","BBB" etc.
2. To have labels in my X-axis (I need to put text as labels). In my eg: - "Start","Point1","Point2" etc.
If I add using Chart.Series(0).Add 20, "AAA", RGB(0, 64, 128) Then "AAA" comes near the point.
I was able to do the 2nd requirement using .Axis.Bottom.labels.Style = talMark.
I need a combination of points 1 and 2.
Can you tell me what settings I need to do to set this.
Any help on this will be really helpfull.
CS
CS
- This is what I am looking for.
- DifferentLabelsInAxis.JPG (24.9 KiB) Viewed 17317 times
Re: Labels in between points in line chart
Hi CS,
You could use the points labels for the bottom axis labels (Start, Point 1,...) and annotation tools (or custom drawing techniques) for the labels between the points (AAA, BBB,...). For example:
TChart1.Aspect.View3D = False
TChart1.AddSeries scLine
TChart1.Series(0).asLine.Pointer.Visible = True
Dim i As Integer
TChart1.Series(0).Add Rnd * 100, "Open", clTeeColor
For i = 1 To 3
TChart1.Series(0).Add TChart1.Series(0).YValues.Value(i - 1) + Rnd * 10 - 5, "Point " + Str$(i), clTeeColor
Next i
TChart1.Series(0).Add TChart1.Series(0).YValues.Value(i - 1) + Rnd * 10 - 5, "Close", clTeeColor
For i = 0 To TChart1.Series(0).Count - 2
TChart1.Tools.Add tcAnnotate
With TChart1.Tools.Items(i).asAnnotation
.Text = Chr(65 + i) + Chr(65 + i) + Chr(65 + i)
.Left = ((TChart1.Series(0).CalcXPos(i + 1) - TChart1.Series(0).CalcXPos(i)) / 2) + TChart1.Series(0).CalcXPos(i) - (TChart1.Canvas.TextWidth(.Text) / 2)
.Top = ((TChart1.Series(0).CalcYPos(i + 1) - TChart1.Series(0).CalcYPos(i)) / 2) + TChart1.Series(0).CalcYPos(i) - (TChart1.Canvas.TextHeight(.Text) / 2)
.Shape.Transparent = True
End With
Next i
In my version I am not getting ".Left " and ".Top " With TChart1.Tools.Items(i).asAnnotation
Various property I can see are ".Position", ".Text", ".Shape". Is there any other way to set the position.
CS
CS
Hi CS,
What TeeChart version are you using? Here is works with both v7 and v8.
version 5.
used "TeeChart5Activex.exe" for installation. We are calling the tchart componets from VB 6.
CS
version 5.
CS
Hi CS,
In TeeChart v5 you can do it with .asAnnotation.Shape.Left and .asAnnotation.Shape.Top instead of .asAnnotation.Left and .asAnnotation.Top.
With the Code you provided I can plot the text in between the points.
Can I cange the Font of the Text which I am plotting.
Also I want to draw a rectangle or square around this label and need an ability to set the color of the Border.
Thanks CS
Thanks CS
Hi CS,
In the example above, with annotation tools, you can set their font and other settings, for example, as follows:
However, the following property in VCL seems not to be implemented in ActiveX. I've adde it to the wish list to be implemented in future releases (TA05015185):
.Shape.Shadow.Visible = False
If (i = 2) Then
.Shape.Font.Color = vbRed
.Shape.Font.Size = 12
.Shape.Font.Bold = True
.Shape.Font.Name = "Comic Sans MS"
End If
End With
Next i
ChartTool1.Shape.Brush.Style:=bsClear;
I tried to use Annotation but I am not able to plot Annotation in the middle of the points.
It works fine when I run the cod eand view the output but when I Export that image to jpeg the points are not on the same Location.
Also I have attached both the screenshot.
Following is Code whcih I am using for Graph generation :
Private Sub Command1_Click()
With TChart1.Export.asGIF
.Width = 850
.Height = 300
.SaveToFile ("C:\Test.gif")
End With
TChart1.ClearChart
With TChart1
.AddSeries (scLine)
.Series(0).Clear
'.Series(0).Marks.Visible = True
.Panel.Color = vbWhite
.Panel.BevelOuter = bvNone
.Panel.Gradient.Visible = False
.Header.Text.Clear
'.Header.Text.Add m_sHeader
.Header.Font.Color = vbRed
.Header.Font.Bold = False
.Header.Font.Name = "Verdana"
.Header.Font.Size = 8
.Tools.Clear
.Footer.Text.Clear
.Footer.Text.Add m_sFooter
.Legend.Visible = False
.Legend.TextStyle = ltsLeftValue
.Legend.Font.Color = vbBlack
.Legend.Font.Name = "Verdana"
.Legend.Font.Size = 8
.Legend.ShapeStyle = fosRoundRectangle
.Legend.ShadowSize = 0
.Walls.Visible = False
.Axis.Left.Title.Caption = "Bps from Arrival Price"
.Axis.Left.Title.Font.Bold = True
.Axis.Left.Title.Font.Name = "Verdana"
.Axis.Left.Title.Font.Size = 10
.Axis.Left.Title.Font.Color = vbBlack
.Axis.Left.AxisPen.Color = RGB(51, 51, 51)
.Axis.Left.labels.Font.Color = vbBlack
.Axis.Left.labels.Font.Name = "Verdana"
.Axis.Left.labels.Font.Size = 8
.Axis.Left.labels.Font.Bold = False
.Axis.Left.GridPen.Visible = False
.Axis.Bottom.AxisPen.Color = RGB(77, 77, 77)
.Axis.Bottom.labels.Font.Name = "Verdana"
.Axis.Bottom.labels.Font.Size = 8
.Axis.Bottom.labels.Font.Color = vbWhite
.Axis.Bottom.labels.OnAxis = False
.Axis.Bottom.Title.Caption = m_sXAxisTitle
.Axis.Bottom.Title.Font.Bold = False
.Axis.Bottom.Title.Font.Color = vbBlack
.Axis.Bottom.GridPen.Visible = True
.Axis.Bottom.GridPen.Style = psSolid
.Axis.Bottom.GridPen.Color = RGB(143, 143, 143)
.Axis.Right.Visible = True
.Axis.Right.AxisPen.Color = RGB(77, 77, 77)
.Axis.Right.labels.Font.Name = "Verdana"
.Axis.Right.labels.Font.Size = 8
.Axis.Right.Title.Caption = m_sXAxisTitle
.Axis.Right.Title.Font.Bold = False
.Axis.Right.Title.Font.Color = vbBlack
.Axis.Right.GridPen.Visible = False
.Axis.Top.Visible = False
.Axis.Top.AxisPen.Color = RGB(77, 77, 77)
.Axis.Top.labels.Visible = False
End With
'TChart1.Aspect.View3D = False
'TChart1.ClearChart
m_lMinLeftAxis = 0
m_lMaxLeftAxis = 0
Dim Point1, Point2, Point3, Point4, Point4TPlusOne, Point4TPlusFive
Dim zeroCorrectingFigure, tmpNumber
tmpNumber = 0
zeroCorrectingFigure = 0
With TChart1
Dim points, labels, i, calcMethodType, CalcCol
.Series(0).asLine.LinePen.Width = 1
.Series(0).asLine.LinePen.Style = psSolid
.Series(0).asLine.LinePen.EndStyle = esFlat
.Axis.Bottom.labels.Visible = True
.Axis.Bottom.labels.Font.Name = "Arial"
.Axis.Bottom.labels.OnAxis = True
.Axis.Bottom.labels.Font.Color = vbBlack
.Axis.Bottom.labels.Style = talText
.Axis.Bottom.MinorTicks.Visible = False
Point1 = -81.11
Point2 = -90.45
Point3 = 23.9
Point4 = 57.87
Point4TPlusOne = 22.88
Point4TPlusFive = -15.23
.Series(0).Add Round(Point1, 2), "P1", RGB(0, 64, 128)
If m_lMinLeftAxis > Point1 Then m_lMinLeftAxis = Point1
If m_lMaxLeftAxis < Point1 Then m_lMaxLeftAxis = Point1
m_lMaxBottomAxis = m_lMaxBottomAxis + 1
.Series(0).Add Round(Point2, 2), "P2", RGB(0, 64, 128)
If m_lMinLeftAxis > Point2 Then m_lMinLeftAxis = Point2
If m_lMaxLeftAxis < Point2 Then m_lMaxLeftAxis = Point2
.Series(0).Add 0, "P3", RGB(0, 64, 128)
.Series(0).Add Round(Point3, 2), "P4", RGB(0, 64, 128)
If m_lMinLeftAxis > Point3 Then m_lMinLeftAxis = Point3
If m_lMaxLeftAxis < Point3 Then m_lMaxLeftAxis = Point3
.Series(0).Add Round(Point4, 2), "P5", RGB(0, 64, 128)
If m_lMinLeftAxis > Point4 Then m_lMinLeftAxis = Point4
If m_lMaxLeftAxis < Point4 Then m_lMaxLeftAxis = Point4
.Series(0).Add Round(Point4TPlusOne, 2), "P6", RGB(0, 64, 128)
If m_lMinLeftAxis > Point4TPlusOne Then m_lMinLeftAxis = Point4TPlusOne
If m_lMaxLeftAxis < Point4TPlusOne Then m_lMaxLeftAxis = Point4TPlusOne
.Series(0).Add Round(Point4TPlusFive, 2), "P7", RGB(0, 64, 128)
If m_lMinLeftAxis > Point4TPlusFive Then m_lMinLeftAxis = Point4TPlusFive
If m_lMaxLeftAxis < Point4TPlusFive Then m_lMaxLeftAxis = Point4TPlusFive
.Series(0).VerticalAxis = aBothVertAxis
.Series(0).asLine.Pointer.Style = psCircle
With .Axis.Left
.SetMinMax m_lMinLeftAxis, m_lMaxLeftAxis + 20
If (((m_lMaxLeftAxis + 20) - (m_lMinLeftAxis - 5)) / 6) > 0 Then
.Increment = Int(((m_lMaxLeftAxis + 20) - (m_lMinLeftAxis - 5)) / 6)
End If
End With
With .Axis.Bottom
.SetMinMax 0, m_lMaxBottomAxis
End With
With .Axis.Right
End If
End With
End With
.Text = "Test"
.Shape.Left = ((TChart1.Series(0).CalcXPos(i + 1) - TChart1.Series(0).CalcXPos(i)) / 2) + TChart1.Series(0).CalcXPos(i) - (TChart1.Canvas.TextWidth(.Text) / 2)
.Shape.Top = ((TChart1.Series(0).CalcYPos(i + 1) - TChart1.Series(0).CalcYPos(i)) / 2) + TChart1.Series(0).CalcYPos(i) - (TChart1.Canvas.TextHeight(.Text) / 2)
.Shape.Transparent = False
End With
Next i
.Width = 850
.Height = 300
End With
TChart1.ClearChart
With TChart1
.AddSeries (scLine)
.Series(0).Clear
.Header.Text.Clear
.Tools.Clear
.Footer.Text.Clear
End With
'TChart1.ClearChart
m_lMinLeftAxis = 0
m_lMaxLeftAxis = 0
tmpNumber = 0
With TChart1
Point1 = -81.11
Point2 = -90.45
Point3 = 23.9
Point4 = 57.87
With .Axis.Left
End If
End With
With .Axis.Bottom
End With
With .Axis.Right
End If
End With
End With
.Text = "Test"
End With
Next i
Hi CS,
You could try exporting the chart to an image using TChart1.Canvas.StretchDraw method.
I am using TChart Version 5 in Visual Basis.
I can't find StretchDraw Method in this version.
Can you give me some other solution to fix this.
CS
CS
Hi CS,
StretchDraw is available in v2010 (aka v9). Many new features and enhancements have been added since v5 was released. We strongly recommend you to have a look at v2010's fully functional evaluation version available at http://www.steema.com/evaluation/ax.
An alternative to StretchDraw, which can be done in v5 too is positioning object in the OnBeforeDrawSeries event. Doing so exports tools correctly. You should remove the code where you add tools and do something like this:
Private Sub TChart1_OnBeforeDrawSeries()
TChart1.Tools.Clear
.Text = "Test"
.Shape.CustomPosition = True
End With
Next i
