TChart Legend
XRS
TChart Legend
Post by XRS » Sun Mar 21, 2010 1:45 am
Is there any way to include the Legend when Exporting a Chart, e.g., as a Bitmap. Text boxes are included, but not Legends. It is included in the Printing methods but not the Copy/Export methods.
Any ideas?
Re: TChart Legend
Post by Yeray » Mon Mar 22, 2010 4:05 pm
Hi XRS,
The following code in VB6:
  'TChart1.Aspect.View3D = False
  TChart1.AddSeries scLine
  TChart1.Series(0).FillSampleValues 25
  TChart1.Export.SaveToBitmapFile "C:\tmp\test.bmp"
Gives the following picture here:
test.zip
(28.1 KiB) Downloaded 481 times
Could you please check it?
XRS
Re: TChart Legend
Post by XRS » Mon Mar 22, 2010 4:51 pm
Yeray,
Thanks for the reply. I investigated further and find that the Legend IS saved and copied/pasted with the BMP format, but NOT with the JPEG format (neither Save nor Copy works).
Brian
Re: TChart Legend
Post by Yeray » Tue Mar 23, 2010 2:39 pm
Hi Brian,
Again, the following code seems to work fine for me here with TeeChart AX 8.0.0.8 under Visual Basic 6. Could you please check if you are using the latest maintenance release available?
  TChart1.Export.asJPEG.SaveToFile "C:\tmp\test.jpg"
XRS
Re: TChart Legend
Post by XRS » Tue Mar 23, 2010 4:28 pm
Yeray,
I am using the menu, not doing this programmatically, and I've created two files, one as a BMP, and one as a JPEG file (see attachment). You can see the difference,
Regards, Brian
test.zip
(132.63 KiB) Downloaded 444 times
Re: TChart Legend
Post by Yeray » Thu Mar 25, 2010 10:46 am
Hi Brian,
The following code tries to do a chart as similar as possible to yours:
  TeeCommander1.Chart = TChart1
  TChart1.AddSeries scArea
  TChart1.Series(0).FillSampleValues 250
  TChart1.Series(0).asArea.AreaPen.Visible = False
  TChart1.Series(0).Pen.Visible = False
  TChart1.AddSeries scVolume
  TChart1.Series(1).Color = vbYellow
  With TChart1.Series(0)
    TChart1.Series(1).AddXY .XValues.Value(50), .YValues.Value(50), "", clTeeColor
    TChart1.Series(1).AddXY .XValues.Value(100), .YValues.Value(100), "", clTeeColor
    TChart1.Series(1).AddXY .XValues.Value(150), .YValues.Value(150), "", clTeeColor
    TChart1.Series(1).AddXY .XValues.Value(200), .YValues.Value(200), "", clTeeColor
  End With
  With TChart1.Legend
    .CustomPosition = True
    .Left = 900
    .Top = 50
    .Transparency = 50
  End With
  With TChart1.Walls.Back
    .Color = RGB(128, 255, 255)
    .Transparent = False
    .Transparency = 50
  End With
Both the generated test.jpg and saving it through the commander gives the same result for me here:
Could you please modify the code above or send us a simple example project we can run as-is to reproduce the problem here?
XRS
Re: TChart Legend
Post by XRS » Thu Mar 25, 2010 7:42 pm
Yeray,
I was not able to duplicate the problem with your project. In the end I was able to fix it on my side by using the custom positioning setup for the Legend, programmatically similar to what you had done, rather than using the Designer to set it up with Percent Margins. The strange thing is that it worked with v.6 and 7 of TChart, but not v.8. It was only a problem with saving to JPEG, not with BMP.
Anyway, thanks for your help,
Brian
Re: TChart Legend
Post by Yeray » Fri Mar 26, 2010 3:24 pm
Hi Brian,
I'm glad to see that you've found a solution that fits your wishes!
